My full LJ SL restoration / build
42 replies to this topic
#1 Filluptheshed
Filluptheshed
  • 49 posts
  • Name:Shane
  • Car:Lj sl 4 door
Posted 28 June 2022 - 06:36 PM
Hi all
I'm a new member and I thought id share my latest resto on a little LJ SL Torana
Taken a while this time round with work , kids ect but finaly getting there almost finished
From the start .....
Enjoy
#2 Filluptheshed
Filluptheshed
  • 49 posts
  • Name:Shane
  • Car:Lj sl 4 door
Posted 28 June 2022 - 06:47 PM
A few more
#3 Filluptheshed
Filluptheshed
  • 49 posts
  • Name:Shane
  • Car:Lj sl 4 door
Posted 28 June 2022 - 06:51 PM
A few more
#4 Filluptheshed
Filluptheshed
  • 49 posts
  • Name:Shane
  • Car:Lj sl 4 door
Posted 28 June 2022 - 06:55 PM
And some more
#5 Filluptheshed
Filluptheshed
  • 49 posts
  • Name:Shane
  • Car:Lj sl 4 door
Posted 28 June 2022 - 07:00 PM
A few more
#6 Filluptheshed
Filluptheshed
  • 49 posts
  • Name:Shane
  • Car:Lj sl 4 door
Posted 28 June 2022 - 07:06 PM
Putting the apprentices to work
#7 Filluptheshed
Filluptheshed
  • 49 posts
  • Name:Shane
  • Car:Lj sl 4 door
Posted 28 June 2022 - 07:10 PM
Some more
#8 Filluptheshed
Filluptheshed
  • 49 posts
  • Name:Shane
  • Car:Lj sl 4 door
Posted 28 June 2022 - 07:14 PM
Yep, a few more
#9 Filluptheshed
Filluptheshed
  • 49 posts
  • Name:Shane
  • Car:Lj sl 4 door
Posted 28 June 2022 - 07:24 PM
Getting there first coupple of layers of 2 pac surfacer down
#10 Filluptheshed
Filluptheshed
  • 49 posts
  • Name:Shane
  • Car:Lj sl 4 door
Posted 28 June 2022 - 07:31 PM
Surfacer Layed down car and panels
#11 Filluptheshed
Filluptheshed
  • 49 posts
  • Name:Shane
  • Car:Lj sl 4 door
Posted 28 June 2022 - 07:42 PM
Playing around with body lines
Was going to go SLR on its ass but decided against it in the end
#12 Filluptheshed
Filluptheshed
  • 49 posts
  • Name:Shane
  • Car:Lj sl 4 door
Posted 28 June 2022 - 07:48 PM
More sanding ready for a few more coats of surfacer , this time in white surfacer as a clean base to start laying colour over
#13 Filluptheshed
Filluptheshed
  • 49 posts
  • Name:Shane
  • Car:Lj sl 4 door
Posted 28 June 2022 - 08:21 PM
In to white surfacer for a clean colour lay down as the colour I decided on is fire orange and is quite transparent also helps with colour light change effect and coverage
#14 Filluptheshed
Filluptheshed
  • 49 posts
  • Name:Shane
  • Car:Lj sl 4 door
Posted 28 June 2022 - 08:29 PM
Finaly getting some colour down on frames and underside of pannels
2 pac Black over 2 pac fire orange and finished off in a high quality 2pac high gloss clear
#15 Filluptheshed
Filluptheshed
  • 49 posts
  • Name:Shane
  • Car:Lj sl 4 door
Posted 28 June 2022 - 08:36 PM
Baked off then carefully fitted all the panels back on and spent quite a bit of time getting all the gaps spot on
#16 Filluptheshed
Filluptheshed
  • 49 posts
  • Name:Shane
  • Car:Lj sl 4 door
Posted 28 June 2022 - 08:41 PM
The weather started to turn and get a bit to cold so moved on with all the other things that needed doing
#17 Filluptheshed
Filluptheshed
  • 49 posts
  • Name:Shane
  • Car:Lj sl 4 door
Posted 28 June 2022 - 09:01 PM
Old motor out ,sanded engine bay , eched primed and then painted in 2pac black
#18 Filluptheshed
Filluptheshed
  • 49 posts
  • Name:Shane
  • Car:Lj sl 4 door
Posted 28 June 2022 - 09:06 PM
Few more of the bay , now time to get started on the new motor
#19 71xu1
71xu1
    Dave
  • 1,275 posts
  • Car:LC GTR XU1
Posted 28 June 2022 - 09:10 PM
Very cool.
#20 Filluptheshed
Filluptheshed
  • 49 posts
  • Name:Shane
  • Car:Lj sl 4 door
Posted 28 June 2022 - 09:19 PM
Time to rebuild the new 202 , all new
Flat top pistons , molly rings , decent cam , ballenced crank , new timing gear
New hy lifters ,push rods running a yellaterra head with matching,YT Rolla rockers , springs and running a tripple su set up and a gated xu1 sump
#21 Filluptheshed
Filluptheshed
  • 49 posts
  • Name:Shane
  • Car:Lj sl 4 door
Posted 28 June 2022 - 09:30 PM
Fitted motor into car along with rebuilt 4 sp box and new performance clutch and flywheel then bolted on new extractors , custom made exaust then modified manifold to height of extractors and bolted on rebuilt tripple su cards
Then hooked it all up wired in and kicked it in the guts for the first time .... ran well so far
#22 Filluptheshed
Filluptheshed
  • 49 posts
  • Name:Shane
  • Car:Lj sl 4 door
Posted 28 June 2022 - 09:38 PM
Custom heat sheild I made up as an afterthought as one of the carbies were spitting fuel Strait onto the extractors while I was tuning them
They are also known to do the same at lights when they get hot and are prone to heatsoak
#23 Filluptheshed
Filluptheshed
  • 49 posts
  • Name:Shane
  • Car:Lj sl 4 door
Posted 28 June 2022 - 09:40 PM
You also may have noticed I've put the body into an orange base that I will sand before painting when it warms up a bit ...
#24 Filluptheshed
Filluptheshed
  • 49 posts
  • Name:Shane
  • Car:Lj sl 4 door
Posted 28 June 2022 - 09:47 PM
Finaly into paint day
2pac fire orange base layed down then left to dry overnight before taping off for black outs then clear over the orange and black base
#25 Filluptheshed
Filluptheshed
  • 49 posts
  • Name:Shane
  • Car:Lj sl 4 door
Posted 28 June 2022 - 09:53 PM
Tapped up car fine lined and ran the black base blackouts
