Normal engine running temp
10 replies to this topic
#1 Suni
Suni
  • 32 posts
  • Name:Suni
Posted 07 July 2022 - 10:29 PM
I have a red 308, 1000km since rebuild. temp gauge sits on 1/4 . .or slightly below .. But pretty much 1/4 on gauge. Is this too low or normal? I do not know where it should be at. I would have thought between 1/4 and 1/2 would be more desirable?
Any advice appreciated.
#2 76lxhatch
  • 7,198 posts
Posted 08 July 2022 - 04:42 AM
I would agree, maybe someone has installed the wrong thermostat (e.g. 160 instead of 180) or removed it altogether? The opening temps are also hit and miss on new ones these days, although usually hotter rather than colder.
edit: Oh, could also just be the gauge, is it reliable? Check the top hose temp with a known good thermometer as a sanity test
Edited by 76lxhatch, 08 July 2022 - 04:42 AM.
#3 Shiney005
  • 9,479 posts
  • Car:Toyota Mirai
Posted 08 July 2022 - 09:18 AM
You can probably buy a cheap aftermarket manual gauge and plumb it in without actually bringing the gauge end into the cabin. Once up to it's normal operating temp, just pull over and have a look under the bonnet.
#4 308 Sunbird
308 Sunbird
  • 973 posts
  • Name:Stuart
Posted 08 July 2022 - 09:44 AM
^^ yep as Laurie said cheap temp and oil pressure gauges are handy to have as an easy "second opinion" to
sometimes sketchy factory gauges, especially after a rebuild.
#5 Ice
  • 15,178 posts
Posted 08 July 2022 - 10:30 AM
1/4 a bit cool for my liking but yeah thermostat would make a difference
#6 Redslur
Redslur
    Has been Torana owner
  • 3,536 posts
  • Name:Gerry
  • Car:HQ GTS Replica 350.
Posted 08 July 2022 - 12:17 PM
Don't guess, put an accurate temp gauge on it and check what it is really doing.
#7 Suni
Suni
  • 32 posts
  • Name:Suni
Posted 08 July 2022 - 05:33 PM
Just ordered an IR  thermometer online. I will get a real reading and report back with results.
#8 Dr Terry
Dr Terry
  • 3,316 posts
Posted 09 July 2022 - 11:14 AM
In my experience, IR thermometers are more accurate if they a reading the temperature of metal (e.g. head or radiator tank) rather than a porous surface like a black rubber hose.
I've had too many inconsistent readings from hoses, check the temp of various spots on the engine & radiator.
Dr Terry
#9 Suni
Suni
  • 32 posts
  • Name:Suni
Posted 09 July 2022 - 05:06 PM
Dr Terry
Would it be correct to take the reading from the inlet manifold? Meaning the block near the manifold or the manifold itself near the block? I really don't know myself.  I have been told that is the hottest part, where the radiator hose to block being the coolest? Noob here trying to work it out.
Edited by Suni, 09 July 2022 - 05:08 PM.
#10 Suni
Suni
  • 32 posts
  • Name:Suni
Posted 14 July 2022 - 09:15 PM
Was able to do real temp readings. It does seem like my temp gauge was maybe out a bit. Just shy of 1/4 on the gauge is 80 degrees for me actual measurement. Which I believe is a pretty good temp to be at. Just past 1/4 on the gauge was 94 degrees. Bloody gauges!
#11 madtoranajzedded
madtoranajzedded
    Sir ask alot
  • 2,893 posts
  • Name:Maz
  • Car:72 LJ SL SEDAN.
Posted 14 July 2022 - 10:02 PM
I used a temp probe and sat that in the top of radiator waited for thermsotat to open read temp then looked at where the temp guage was sitting in cabin.
