Twin charged Supercharged Turboed VY UTE sneek peek
SuperchargedTurbo VY ute
3 replies to this topic
#1 Filluptheshed
Filluptheshed
  • 49 posts
  • Name:Shane
  • Car:Lj sl 4 door
Posted 10 August 2022 - 11:06 PM
Hi guys just thought id give you all a look at one of my other projects that has been put on hold until I finish my LJ torana restoration
The Torana is almost finished so this will be underway to be completed soon
T4 turbo to water to air intercooler to supercharger to water to air intercooler no 2 then into a custom mase air to air mase plate into engine ...
Stand alone ecu full custom wiring harness made ect ect ... the list so far is in the pics
Few small things to sort out and she should be a runner , performance shop that I've been harassing along the way thinks I may have to run a bypass around the supercharger for when it hits full boost (around 22psi) with a gate in the pipe and sintrifical clutch on the supercharger pully so I don't overdrive the charger
And I'm pritty much garenteed to blow the 5 sp box behind it and will have to convert to a 6 sp ls1 box and diff
Anyhow I'll keep you posted when I get back to work on it
until then I'll be putting the finishing touches on the torana build ready for rego ( full build in members projects )
Thanks for checking it out
#2 SHEEL
SHEEL
  • 345 posts
  • Name:Daniel
Posted 31 August 2022 - 10:34 AM
wow you've packaged that really well... I bet it'll sound awesome!
#3 Filluptheshed
Filluptheshed
  • 49 posts
  • Name:Shane
  • Car:Lj sl 4 door
Posted 01 September 2022 - 12:29 AM
Hopping so should find out in a coupple of weeks has a custom exaust built for it so trile and error at this stage
#4 SHEEL
SHEEL
  • 345 posts
  • Name:Daniel
Posted 02 September 2022 - 10:05 AM
If it were me, I'd be running some good mufflers to keep the Mang noises to a minimum, whilst hopefully getting all the whoosh and whizz noises to be the main show!
