Transmission cooler lines V8 Trimatic LX
7 replies to this topic
#1 Screamin
Screamin
  • 51 posts
  • Name:Richard
  • Car:LX 4 door with 253
Posted 14 September 2022 - 10:56 PM
Hi members
I have just sourced a V8 trimatic to put in my 308 LX but don’t have the cooler lines. I am converting from manual.
Have any of you made your own or is buying new my only realistic option?
#2 LXCHEV
LXCHEV
  • 3,537 posts
  • Car:'76 LX - 383 Chev
Posted 15 September 2022 - 10:31 AM
You don't have to run hard lines. I've had rubber lines in my car for 25 years (TH350 to a B&M trans cooler mounted in front of the radiator), and still going strong.
On the note of trans coolers, I would encourage you to run a standalone trans cooler, rather than using a radiator with the integrated cooler. If you're converting from manual, I assume that's your plan anyway?
#3 Cook
Cook
  • 1,523 posts
Posted 15 September 2022 - 10:32 AM
Hi Richard. I made my own because I had to. Running T400 so different set up to you. I did have to drill 2 holes in the radiator support panel for them to run through but no big deal. Cheers Ron
#4 Cook
Cook
  • 1,523 posts
Posted 15 September 2022 - 10:57 AM
Some pics FWIW. Cheers Ron
#5 Screamin
Screamin
  • 51 posts
  • Name:Richard
Posted 05 October 2022 - 10:58 PM
Thanks fellas. I was considering using the radiator for trans cooling but am now thinking the seperate cooler is the better option. Especially in the hot WA summers. Appreciate the photos too. Nice neat job.
#6 kudu
kudu
  • 1,454 posts
  • Car:LH SL/R 5000
Posted 08 October 2022 - 07:15 AM
Is it that much of an issue if you use a radiator with the trans cooler built in?
#7 Rockoz
Rockoz
  • 4,008 posts
  • Name:Rob
Posted 08 October 2022 - 08:20 AM
Cooling lines running through the radiator have been known to fail often.
End up with a pinky coloured transmission fluid and all sorts of gear change problems.
If the transmission gets hot, it increases the temp of the water going back to the engine.
If the engine gets hot, it increases the temperature of the fluid in the box.
Neither are ideal.
Reckon it was a purely cost saving measure from the manufacturers using in radiator cooling.
Rob
#8 S pack
  • 15,668 posts
Posted 08 October 2022 - 08:32 AM
I had read that having the transmission oil cooled by the radiator also helps to warm the transmission up faster from cold start.
