Hi,
Wondering if anyone has had this particular issue -
Aussie 4 speed, rebuild 12m ago. Was running perfectly.
Rebuilt by a guy who 100% knows what he is doing, did 2 boxes for us. The other one is perfect.
New bearings and gears as required etc, new synchros. New oil.
Was all good for around 10 months. Car has only done about 200 road km and about the same on circuits.
The crunchy-new started as minor, and could be covered up if you heel and toed it. Now it just crunches, regardless.
Pulled the box out and drained the oil...99% brand new.
Selectors all good, shifter good.
If I select 1st, 2nd, 3rd, 4th up and down with my fingers inside the actual box, it all happens smoothly and gracefully.
No evidence internally of any metal to metal type activity. Gears & Synchros look brand new.
Before removing the gearbox , jacked up arse end of car with it in gear, and got a mate to try and rotate the rear wheels, and yell out when they moved, ( as I pressed the clutch in.) = about 1/2 way between foot off the pedal - and pedal on floor. Assume this is good. No drag once disengaged.
Have not removed bellhousing and clutch to inspect, as don't see a need to?
Only thing I have found even slightly iffy is the main input bearing seems sloppy...strange, as it is clearly new.
Could that slop transfer down the shaft and cause enough misalignment to cause the crunch as gears slide into the required selection?
TIA
