LH Gpak Build
161 replies to this topic
#51 hawk
hawk
  • 2,211 posts
  • Name:steve
  • Car:UC Torana
Posted 08 March 2023 - 08:16 PM
Thanks Yel, I saw the muncie for 3k. I think Dad is keenest on a chev because he had an Slr with the 350 back in NZ when he was younger.
I'd say that the Hq above is more than he'd be willing to spend at the moment. Best off waiting a few more months as prices are still dropping and there's some good stuff popping up.
Dad finished off the floor repair and laid down some KBS rust proof paint.
Attached File  received_3391780601036476.jpeg   163.29K   7 downloads
The wiring in this car is totally butchered. when the thermo fans come on the engine virtually dies because of the current draw. So naturally, I ripped it all out.
Attached File  20230308_165609.jpg   145.85K   6 downloads
along with the thermo fan wiring, there was an aftermarket alarm system fitted which I don't think had been operational for years.
Attached File  20230308_184322.jpg   139.08K   7 downloads
#52 yel327
  • 13,790 posts
Posted 10 March 2023 - 08:47 AM
This isn’t badly priced, I think it’s a GenII Vortec so technically not a Chevy engine but at least looks like one. Rebuilt and balanced with a flywheel too. Just needs that Muncie on Foolbook and a clutch. Should cool fine with a HJ-HZ 3 row radiator. I think you would just use an LH-LX V8 throttle pedal and cable.
http://www.gumtree.c...&utm_source=sms
#53 Cook
Cook
  • 1,534 posts
Posted 10 March 2023 - 01:50 PM
What sort of emissions gear would you have to run with that.  Only reason I raise it is that I think this is being looked at a bit closer in Vic. at present. I went to discuss my set-up with an engineer recently and he suggested I might need cats with a QT prefix engine. Naturally I'm not talking to him any further. Cheers Ron
#54 yel327
  • 13,790 posts
Posted 10 March 2023 - 02:17 PM
It depends on the engine and the car in NSW and I doubt VIC would be any different if they are using the NCOP. On an LH you don't need anything to run a 6/76 and earlier 308 block other than a sealed fuel tank, canister and the correct carby for the transmission. If the LH is pre 1/75 all you need is the ADR26 stuff, not even a canister. As far as SBC or GENII engines, if the block is pre 1972 same as a above, assuming engine size constraints are OK. If it is after that then best bet is a crate engine block, although some Engineers will say if it is quacks and looks like a SBC block (2 piece rear main etc) then it is OK, just like they say QT or 11QT prefix is fine (we all know a lot of these are ADR27A). I've been told for my 427 in my GTS327, if it looks like a BBC then it'll be fine, so I can use a 1972-1980 block if I need to, but now have a 1970 block for it.
#55 yel327
  • 13,790 posts
Posted 11 March 2023 - 06:17 PM
Hawk, this might work in the LH with a 308 or 253.
Would need a modified UC clutch pedal.
#56 hawk
hawk
  • 2,211 posts
  • Name:steve
  • Car:UC Torana
Posted 11 March 2023 - 07:13 PM
Thanks Yel, I sent it through to dad. I might even try and grab it for my car. Seems pretty cheap really.
I think Dad mainly wants to focus on finishing the body work before anything else. He is currently working on the rear floorpans at the moment.
#57 hawk
hawk
  • 2,211 posts
  • Name:steve
  • Car:UC Torana
Posted 11 March 2023 - 07:40 PM
Missed out on the box, he already sold it.
#58 yel327
  • 13,790 posts
Posted 12 March 2023 - 07:29 AM
Damn, have to be fast! Here is another I saw at the same time. Bit dearer but comes with more. Has a HX Holden style clutch mech on it. I always wondered if this would fit a Torana and work with an LH-LX V8 clutch pedal and cable. It comes with pedals so you could work out the ratios off the HX clutch pedal.
Edited by yel327, 12 March 2023 - 07:30 AM.
#59 hawk
hawk
  • 2,211 posts
  • Name:steve
  • Car:UC Torana
Posted 22 March 2023 - 08:25 PM
Well dad started on his replacement drivers side door. Rust free frame although had a few rust holes along where the rubber bump strip sat. Anyway, he tried to replace the strip against my advice and the skin is now warped to buggery. He has set it aside for now until he works out what to do with it.
Attached File  20230314_163537.jpg   246.18K   7 downloads
In the mean time he has started work on the parcel shelf top section that was in 3 pieces.
Attached File  20221124_135740.jpg   281.29K   6 downloads
All tied in together for the most part
Attached File  20230322_182859.jpg   566.5K   6 downloads
Attached File  20230322_182903.jpg   562.32K   6 downloads
And test fitment
Attached File  20230321_175138.jpg   197.64K   7 downloads
#60 Uncle Chop Chop
Uncle Chop Chop
    Grumpy Old Man
  • 1,409 posts
  • Name:John
Posted 23 March 2023 - 05:56 PM
Nothing like a air of vice grips and a 12" shifter, is there? As long as it doesn't move whist you're welding, that's the only important thing.
#61 claysummers
claysummers
  • 3,716 posts
  • Name:Clay
Posted 23 March 2023 - 07:32 PM
Tricky job on the door. You’ve got to turn up the heat so you get even penetration. Stops it from pulling in at the weld. Very slowly and evenly. Control the heat. Knowing the theory is only the first step. If you can get a strip of copper earth strap like they use in substations up hard behind it it will draw the heat and also prevent blow through.
#62 yel327
  • 13,790 posts
Posted 28 March 2023 - 10:17 AM
Shame you aren’t in WA Hawk. This guy has radiator, extractors and exhaust suit SBC into LX. Almost free.
#63 hawk
hawk
  • 2,211 posts
  • Name:steve
  • Car:UC Torana
Posted 28 March 2023 - 08:09 PM
Geez that stuff is cheap.
Have sourced a couple more bits for this car and my car recently. Dad ended buying another drivers door that is a lot better.
Got the parcel shelf top section in KBS paint and finished off for now. It will be fitted last. The curve is a little off on the passengers side but should be easy enough to adjust.
Attached File  20230328_150117.jpg   239.58K   6 downloads
The passengers rear floor has got a couple of patches with a couple more needed.
Attached File  received_1349317919181805.jpeg   181.04K   5 downloads
Attached File  received_799485714870142.jpeg   186.26K   5 downloads
Attached File  received_5433938966707082.jpeg   176.36K   5 downloads
Attached File  received_766397104828050.jpeg   180.36K   6 downloads
Attached File  20230328_144937.jpg   192.6K   4 downloads
#64 Heath
  • 18,403 posts
Posted 29 March 2023 - 08:25 AM
Keep at it. Getting some good results here mate.
#65 hawk
hawk
  • 2,211 posts
  • Name:steve
  • Car:UC Torana
Posted 30 April 2023 - 07:43 PM
Just a quick photo dump of some recent progress.
rear floor pan repairs completed, rust converted and painted in KBS.
Attached File  received_891351142119802.jpeg   206.07K   6 downloads
Attached File  received_1139661253378749.jpeg   206.38K   5 downloads
Attached File  received_241992135005729.jpeg   209.96K   5 downloads
Attached File  20230406_123410.jpg   135.4K   5 downloads
#66 hawk
hawk
  • 2,211 posts
  • Name:steve
  • Car:UC Torana
Posted 30 April 2023 - 07:46 PM
Drivers side floor pan needed a couple of patches.
Attached File  received_930440848265348.jpeg   188.94K   5 downloads
Attached File  received_735343621713405.jpeg   195.67K   5 downloads
Attached File  received_779203503612612.jpeg   137.32K   5 downloads
Passengers front floor is the worst by far and is all coming out.
Attached File  received_208696095208489.jpeg   230.84K   5 downloads
Attached File  received_612750860908108.jpeg   183.61K   5 downloads
#67 Heath
  • 18,403 posts
Posted 01 May 2023 - 11:35 AM
You're putting a reproduction floor section in on that side, I imagine?
The repairs are looking good.
That isn't the advice I would give, lol.
#68 claysummers
claysummers
  • 3,716 posts
  • Name:Clay
Posted 01 May 2023 - 05:03 PM
Well don’t keep us in suspense Heath….
#69 Heath
  • 18,403 posts
Posted 04 May 2023 - 10:48 AM
Sorry, I probably sounded a bit rude there. Maybe we need some more information, are you suggesting doing the same job as above, but just with the amps turned up and a strip of copper behind it? Is that really going to make it work any better? Is there a particular sequence of welding and/or cooling it along the way? (I must admit I'm not even quite sure how you clamp the copper in place well)
I would just avoid MIG welding a strip down the middle of a door skin in the first place.
But I guess if I had to do this repair, I'd remove the skin, weld the section in with a TIG so I could actually planish the weld and panel beat the repair generally to get it into shape, and then re-fit the skin.
It's an awful repair, though. Fortunately they do make replacement skins although they aren't super cheap.
#70 claysummers
claysummers
  • 3,716 posts
  • Name:Clay
Posted 04 May 2023 - 12:42 PM
I use various methods to hold copper and alloy heat sinks behind the weld, including tek screws through the panel, propping from behind, masking tape, and just holding with one hand and mig with other. It enables me to turn the heat up and get good penetration on pitted panels. I need to get oxy I know but haven't got around to it yet. As for TIG I'm completely ignorant in that respect.
Agree that I would likely get a full skin replacement if possible. I haven't had much luck doing large panels like that. Did have some success with lower rear quarter replacement. You can get in behind with dollys and planish with the doors though. The panel van quarter panels require some serious contortion, and that is on a rotisserie.
#71 Uncle Chop Chop
Uncle Chop Chop
    Grumpy Old Man
  • 1,409 posts
  • Name:John
Posted 04 May 2023 - 07:36 PM
Virtually every time I saw somebody use a slab of copper as a heatsink, it was held in place by hand. Mind you, the times it was used was always on a small section. Nothing like the full length of a door skin.
#72 yel327
  • 13,790 posts
Posted 04 May 2023 - 07:52 PM
You should never hold any metal by hand when welding. Great way to give yourself an electric shock. Nowadays about 20-25% of reported electric shocks are by those welding or plasma cutting and they are always caused by the welder (you) becoming part of the welding circuit. If you are going to hold anything being welded wear dry welding gloves and use a DC welding machine, but preferably don’t touch anything attached to the welding circuit.
#73 claysummers
claysummers
  • 3,716 posts
  • Name:Clay
Posted 04 May 2023 - 09:32 PM
Good advice Byron. I did feel a tingle once. It also gets too hot to hold quite rapidly. When I mini-tubbed my van I used a length of the substation earth grid type copper strap, tek screwed underneath along the weld gap from above. Worked well to hold the filler strip flush and minimise linshing required inside the tub, as well as eliminate blow through.
#74 Uncle Chop Chop
Uncle Chop Chop
    Grumpy Old Man
  • 1,409 posts
  • Name:John
Posted 04 May 2023 - 09:38 PM
Just to clarify, a bare hand wasn't used. It was more that the block was held by a tool with an insulated grip, which was in turn placed against the metal work by hand. As opposed to being clamped etc. to the metalwork.
#75 Heath
  • 18,403 posts
Posted 08 May 2023 - 09:36 AM
If you TIG weld regularly, you'll definitely find a way to electrocute yourself lol. It has never been a problem, but it has been difficult to avoid, haha.
