Head Bolt Glue
Posted 03 November 2022 - 02:59 PM
Posted 03 November 2022 - 03:25 PM
Haven't bought it for a very long time - but the old tin on my shelf here is the same as the first one you mentioned - the original GMH Holden 'Sealing Compound' - Part #3835215 (250ml tin).
Looking online, there's not much on ebay.
I did find the following AC Delco branded equivalent / replacement: might be worth a look:
https://www.autolink...-paper-g~203623
Posted 03 November 2022 - 05:19 PM
Posted 03 November 2022 - 07:38 PM
Have used permatex aviation sealant quite a bit without any issues.
Posted 03 November 2022 - 09:06 PM
What Rodney said!
Posted 03 November 2022 - 10:28 PM
I’ve got an old one of these with permatex brand name on it.
Label looks virtually identical.
Permatex used to own loctite, not sure if they still do
But it must be the same stuff.
The permatex/loctite chart lists
Aviation form-a-gasket no. 3 as the equivalent to loctite 5923,
but not the loctite no.3, strangely.
Recently used my old one on some rocker studs and it didn’t leak.
Googling about the gmh stuff leads back here to old threads,
and there are even more types guys swear by, so there must be
plenty of different ones that will do the job
Posted 04 November 2022 - 02:09 AM
Always thread chase, and not tap holes clean.
Use new Head Bolts.
The use of Non-setting sealant, as above, is best so you can re-torque later.
Posted 04 November 2022 - 05:47 AM
I concur.
Posted 04 November 2022 - 07:18 AM
Steam flange/thread sealer should do the job.
Posted 07 November 2022 - 07:24 PM
Posted 07 November 2022 - 09:52 PM
Actually, I've used the ARP stuff also with good success, but only on the current engine, alloy headed 308.
https://arp-bolts.co...php?RecordID=85
Posted 08 November 2022 - 07:16 PM
Posted 09 November 2022 - 09:46 AM
