3 Speed vacuum advance switch ?
5 replies to this topic
#1 UCSLE
UCSLE
  • 703 posts
  • Name:troy
  • Car:Goggomobil
Posted 15 November 2022 - 04:54 PM
have a old smooth case 3 speed here that i have just started working and noticed there is a switch on the 2-3 selector .
Is it supposed to have one ? thought only later boxes got them
also notice there is no flat spot on the shaft for the switch to work compared to the 4 speed
I'm guessing the gearbox is a bitsa
Picture is of the cover off the 3 speed
Attached File  cover.jpg   243.51K   2 downloads
Attached File  DSCF4075.jpg   194.75K   2 downloads
#2 claysummers
claysummers
  • 3,566 posts
  • Name:Clay
Posted 15 November 2022 - 05:02 PM
I put a smooth case one in a car just last week or I could have checked the part number, but definitely no switch on the selector shafts. Would have commenced in HX 1977.
#3 yel327
  • 13,575 posts
Posted 15 November 2022 - 05:07 PM
Yes started with ADR27A in some late Pagewood HJ.
#4 Dr Terry
Dr Terry
  • 3,316 posts
Posted 16 November 2022 - 06:51 AM
That 2-3 shaft is from an early gearbox. It has an o-ring & no cut-out for the switch.
The later shaft requires no o-ring because there is a proper seal in the gearbox, which you can see in the pic.
Dr Terry
#5 UCSLE
UCSLE
  • 703 posts
  • Name:troy
  • Car:Goggomobil
Posted 16 November 2022 - 07:53 PM
that makes sense,  might have at look at making a new cover or just making a bush so its not seal on seal
#6 yel327
  • 13,575 posts
Posted 16 November 2022 - 08:03 PM
Just find the right fit HK to HJ side cover off a 3spd or 4spd. Still heaps around.
