LX Cigarette Lighter Assembly Help
7 replies to this topic
#1 Cook
Cook
  • 1,523 posts
Posted 04 December 2022 - 11:59 AM
Hi all. I'm trying to put my cigarette lighter back together and can't find any old photos etc as to how it all goes together.  Here is a pic of the parts and I suspect I may be missing something.  Also not even sure if this is the correct type. Conversely is there a quick fix replacement one on the market. Thanks in advance. Cheers Ron.
#2 Statler
  • 6,304 posts
Posted 07 December 2022 - 02:28 PM
Hold #1 in place. The small hole will locate to an ashtray screw.
Insert #5 into the dash., through #1
#4 should then screw onto # 5 , holding it all together.
I'm guessing $3 goes on next folowed by #2.
Fit the wire & i;m guessing #6 is the nut.
#3 Cook
Cook
  • 1,523 posts
Posted 08 December 2022 - 04:04 PM
Thanks Col. I agree with your logic but I had a feeling I was missing a pin connection somewhere so in the meantime I bought a socket from Aaron "all auto recreations" which was listed as replacement for LX, among other models. It said it was a two pin style, which I presume meant 1+ve and 1-ve. Now I'm a bit confused as there are 2 middle pins and one on the chassis (which would be for the earth) as per the pic. From what I can see on the wiring diagram there is only one wire (brown) for the lighter so how is this wired up. To be fair to Aaron I haven't contacted him yet. Cheers Ron
#4 Rockoz
Rockoz
  • 4,008 posts
  • Name:Rob
Posted 08 December 2022 - 06:18 PM
The other pin was often used to easily power stuff like CB radios.
It was a handy power take off point if it was fitted.
Rob
#5 Cook
Cook
  • 1,523 posts
Posted 08 December 2022 - 06:49 PM
Ok cool. Thanks for that Rob. So I could use it for the power source for the hidden aerial I have bought. Is there an issue if it exposed without being used? Cheers Ron
#6 Cook
Cook
  • 1,523 posts
Posted 19 December 2022 - 09:07 AM
Finally got it all hooked up and dash in. The bit that I thought would be the easiest (crash pad) was the most difficult but got there.  Light at the end of the tunnel, now I am just waiting to see which train is coming lol.  Cheers Ron
#7 Rockoz
Rockoz
  • 4,008 posts
  • Name:Rob
Posted 19 December 2022 - 09:42 AM
Should be no drama with it being exposed.
But if you want a little peace of mind, just grab an insulated spade terminal and shove it over the unused tab.
Rob
#8 Cook
Cook
  • 1,523 posts
Posted 19 December 2022 - 04:22 PM
Thanks Rob. All good. I ended up using for the power source for the hidden aerial. Cheers Ron
