LH lower dash - DYI plastic repairs
11 replies to this topic
#1 blackout
blackout
  • 19 posts
  • Car:LH
Posted 22 January 2023 - 02:59 PM
Hi fellas- looking for suggestions.
Trying to tidy up a previously butchered lower dash.
Missing a chunk of plastic (drivers side upper part where it meets the crash pad)
Was thinking fine steel mesh and some sort of epoxy? (not sure what sort of epoxy will bond)
CheersAttached File  9C4D7DA7-188D-4F07-BF20-F9BAA2BBBA1A.jpeg   208.43K   11 downloads
#2 hanra
  • 10,920 posts
Posted 22 January 2023 - 03:16 PM
Buy a glove box lid and go to town with it.
#3 Cook
Cook
  • 1,523 posts
Posted 23 January 2023 - 09:21 AM
Hi. I recently did some repairs on my dash and console. Got a sheet of plastic from a local supplier (wrinkled but not a good match).Stuck the pieces as well as I could with superglue then went over the undersides with backing strips for extra support and smothered in fibreglass. Used a bit of plastic filler where required and carefully rubbed back excess. That section is where the crash pad slots into it so would not be able to reinforce the rear at the very edge.  Biggest problem is trying to get the wrinkled effect. I was lucky enough that where I couldn't match, it was not noticeable. Seen some posts on here where some really good repairs have been done.  One method is to dab paint on with a sponge to add effect. I would try even doing this (on a sample piece) with plastic filler that has not yet quite hardened. Bit of trial and error. Worst case scenario it doesn't work first time so just try again. Cheers Ron
#4 blackout
blackout
  • 19 posts
  • Car:LH
Posted 24 January 2023 - 01:26 PM
Cheers Ron
Do you know what sort of plastic you used?
#5 Cook
Cook
  • 1,523 posts
Posted 24 January 2023 - 03:51 PM
Pretty sure it was ABS. Cheers Ron
#6 WhaleOilBeefHooked
WhaleOilBeefHooked
  • 1,671 posts
  • Car:LJ GTR
Posted 27 January 2023 - 08:10 PM
This would be the perfect solution to your problem, right thickness material and even right grain to said material, you could either superglue or plastic weld and sand it back to look almost unidentifiable to damageā€¦
#7 Rockoz
Rockoz
  • 4,008 posts
  • Name:Rob
Posted 28 January 2023 - 09:14 AM
A Dremel with fine grinding tips would be handy for making the creases match up.
And a steady hand and patience.
They can do very fine detail work.
Handy for all sorts of jobs restoring.
I use mine to cut out fiddly areas of steel/rust for replacement.
Rob
#8 VDO
VDO
  • 187 posts
  • Name:Chris Curtis
Posted 28 January 2023 - 01:53 PM
Fill with JB weld with some backing re-inforcement, smooth out, finish with wrinkle finish paint.
#9 Kirk
Kirk
  • 841 posts
  • Name:Kirk
  • Car:LX SS 253
Posted 28 January 2023 - 11:01 PM
I may have a broken console that you can have a piece big enough to repair that
Im in western Sydney
#10 Cook
Cook
  • 1,523 posts
Posted 29 January 2023 - 09:01 AM
Also forgot to mention I did use some hot staples on backs of parts but with limited success.  bit of fun but need to practice. Not sure if they would fit in that section. Given the price of glovebox lids not viable and they are smooth so no value to replicate texture. Cheers Ron
#11 blackout
blackout
  • 19 posts
  • Car:LH
Posted 26 February 2023 - 11:18 AM
Cheers guys - ended up using sheet metal as backing and then plastic weld /body filler. Seems to have bonded pretty good.
#12 blackout
blackout
  • 19 posts
  • Car:LH
Posted 26 February 2023 - 12:08 PM
