LJ heater box cable grommet.
22 replies to this topic
#1 IanC
IanC
  • 574 posts
  • Name:Ian
  • Car:LJ XU-1
Posted 24 January 2023 - 05:16 PM
Anyone know if you can buy a heater box cable grommet anywhere ?.
#2 Indy Orange
Indy Orange
  • 2,901 posts
  • Name:Paul
Posted 25 January 2023 - 01:14 AM
Ian, if you mean the cable that comes out of the top of the shelf , I’m pretty sure it was just a blob of goop
Around the cable.
#3 S pack
  • 15,666 posts
Posted 25 January 2023 - 07:07 AM
Paul, there is a rubber grommet. LC have a small grommet on the cable where it penetrates through the upper dash panel and LJ have a larger rubber grommet.
#4 IanC
IanC
  • 574 posts
  • Name:Ian
  • Car:LJ XU-1
Posted 25 January 2023 - 07:19 AM
This is off the forum 2009. https://www.gmh-tora...&attach_id=1584
https://www.gmh-tora...&attach_id=1583
#5 S pack
  • 15,666 posts
Posted 25 January 2023 - 08:24 AM
Don't know about the grommet in those pics. The original cable in my LJ the grommet was just flat on both sides, as are the grommets on the spare part replacement cables. Nothing like the one in those pics.
IIRC Marty found a work around for the grommet during the resto of his LJ. Search the Marty Report.
Edited by S pack, 25 January 2023 - 08:26 AM.
#6 IanC
IanC
  • 574 posts
  • Name:Ian
  • Car:LJ XU-1
Posted 25 January 2023 - 08:47 AM
Will do Dave. Cheers mate.
#7 Indy Orange
Indy Orange
  • 2,901 posts
  • Name:Paul
Posted 25 January 2023 - 09:03 AM
Well there ya go! Never knew that!
Did they have a sealant additional to the grommet?
#8 IanC
IanC
  • 574 posts
  • Name:Ian
  • Car:LJ XU-1
Posted 25 January 2023 - 09:28 AM
If I can't find anything suitable, I think I will use a 17mm grommet, and some black silastic.
#9 S pack
  • 15,666 posts
Posted 25 January 2023 - 10:23 AM
Yes, they had a blob of mastic type sealant covering the grommet.
#10 Indy Orange
Indy Orange
  • 2,901 posts
  • Name:Paul
Posted 25 January 2023 - 03:51 PM
I guess it wasn’t seen as it’s under the goop.
#11 jd lj
jd lj
  • 2,108 posts
  • Name:James D
  • Car:LJ SVO
Posted 25 January 2023 - 04:48 PM
GMH did a pretty rough job when they put the sealant over the grommet. They were quite messy. Do ut left handed if you want it to look original.
#12 Indy Orange
Indy Orange
  • 2,901 posts
  • Name:Paul
Posted 25 January 2023 - 06:45 PM
Sure did James, I’ve seen original XU1s with that sealant obviously formed by hand because you can see the finger marks .
#13 Indy Orange
Indy Orange
  • 2,901 posts
  • Name:Paul
Posted 25 January 2023 - 07:42 PM
This is what we’re talking about, I haven’t done anything with mine yet but I’ll find a rubber seal for it sometime,it could be similar to the reverse switch wiring grommet on the transmission tunnel.
Edited by Indy Orange, 25 January 2023 - 07:43 PM.
#14 jd lj
jd lj
  • 2,108 posts
  • Name:James D
  • Car:LJ SVO
Posted 26 January 2023 - 05:55 AM
The hole for the cable in LJ's is much bigger than that, I'd say 3/4" from memory.
On your wiper motor you've got a bolt holding the front plate just below the earth strap bolt. On LC and LJ's that one should be left empty. Apparently it was there for the HQ earth strap IIRC.
#15 S pack
  • 15,666 posts
Posted 26 January 2023 - 07:17 AM
This is what an LJ Heat control cable grommet looks like.
Attached File  LJ heat control cable 1.jpg   27.62K   7 downloads
Attached File  LJ heat control cable 2.jpg   25.72K   4 downloads
Attached File  LJ heat control cable 3.jpg   30.01K   5 downloads
#16 Indy Orange
Indy Orange
  • 2,901 posts
  • Name:Paul
Posted 26 January 2023 - 09:35 AM
The LC grommet must be quite small then .
#17 IanC
IanC
  • 574 posts
  • Name:Ian
  • Car:LJ XU-1
Posted 26 January 2023 - 04:17 PM
How do you get that over the mounting block with out tearing it?. And where can I get one.. :)
#18 S pack
  • 15,666 posts
Posted 26 January 2023 - 04:41 PM
Sorry Ian, AFAIK the grommet was installed onto the cable before the plastic end was moulded on during manufacture back in the 70's or 80's.
I have no idea if repro grommets are available.
#19 claysummers
claysummers
  • 3,559 posts
  • Name:Clay
Posted 26 January 2023 - 05:55 PM
Have a look at Fitch or similar. Just have to cut it and slip over the cable. Cut won't be noticeable.
#20 jpxu1
jpxu1
  • 567 posts
Posted 26 January 2023 - 06:51 PM
You'll be surprised just how far they will stretch, Use a pair of circlip pliers and a smidge of rubber grease.
#21 Indy Orange
Indy Orange
  • 2,901 posts
  • Name:Paul
Posted 28 January 2023 - 08:26 PM
Ta James ! How’s that?
#22 jd lj
jd lj
  • 2,108 posts
  • Name:James D
  • Car:LJ SVO
Posted 29 January 2023 - 06:27 AM
Ah, that's better. I only know this by making the same mistake in the past myself and having a very knowledgeable friend inform me of how they should be.
#23 stealthxu1
stealthxu1
  • 350 posts
  • Name:Stealth
  • Car:lc 2 door project
Posted 03 February 2023 - 09:30 PM
I have one ill sell
Lake Macquarie area
