Ignition Leads
Posted 05 February 2023 - 07:37 PM
What ignition leads would you recommend?
I don’t see many options at super cheap or repco.
Repco has OEX.
Is it best to just buy these online?
Posted 05 February 2023 - 10:28 PM
Eagle 10 mm leads
Posted 07 February 2023 - 07:00 AM
Eagle 10 mm leads
10mm leads are showcar BS. 10mm leads don't provide any more spark.
8mm is more than enough. Eagle are a good brand however.
Dr Terry
Posted 21 February 2023 - 01:42 PM
Posted 21 February 2023 - 03:59 PM
Posted 21 February 2023 - 04:44 PM
Posted 22 February 2023 - 08:46 AM
If you are using right angle leads, then I would suggest there is no "right" way of doing it, as all of the factory ones were straight. There isn't much room for right anglr leads on the small dizzy cap, but easy if electronic ignition.
Rally-EmsBirthday-Car016.jpg 114.25K 4 downloads
Posted 22 February 2023 - 10:21 AM
Posted 22 February 2023 - 10:34 AM
Dr Terry
Good to know!... I had some Bosch 8mm leads and was wondering if they were going to do the job alright. Guess I'll give them a go and see what happens..
Posted 22 February 2023 - 10:37 AM
Posted 22 February 2023 - 10:35 PM
Posted 23 February 2023 - 08:31 AM
Repco has OEX.
I fitted an OEX alternator to my ute at 310,000 kays. It died at 400,000. It wasn't just brushes either. A bearing failed and it completely fell to bits.
Posted 24 February 2023 - 06:32 AM
Yes not much room at all on the original dizzy cap for the right angle leads . I’m not sure why most leads available now are like this as years ago they were mostly straight
The factory leads for the Blue/Black (carby) Holden V8 were always 90 degrees at the cap end.
If you look in the factory workshop manual it shows how to lay them out.
Dr Terry
Posted 24 February 2023 - 06:51 AM
Posted 24 February 2023 - 08:12 AM
Posted 24 February 2023 - 09:06 AM
Posted 25 February 2023 - 08:25 AM
I have a NOS set of 1974 dated leads and they are straight, so I am assuming all red motors were fitted with them.
New L34 motor.JPG 367.14K 5 downloads
Posted 25 February 2023 - 09:33 AM
Posted 25 February 2023 - 10:10 AM
Yes and back in the 80s all the replacement ones were straight but now all the brand name ones have the right angle plug
I think some on here might be confusing their Red V8s with Blue/Black V8s.
I stock new ignition leads & all 4 brands on my shelf for the Red V8 have straight ends & they are designed to fit the smaller female style cap.
The leads I have in stock for the Blue/Black V8s suit the larger cap with the male terminals & have 90 degree end boots.
The leads for the later 5.0 EFI motor are designed to fit the smaller car with female terminals as per the old Red V8s, but have 90 degree boots.
Dr Terry
Posted 25 February 2023 - 12:11 PM
https://www.kingswoo...-308-red/TG8010
#21
Posted 26 February 2023 - 12:04 PM
Bosch, PAT (Premier Auto Trade), Top Gun & Eagle.
See: https://autobarn.com...8002I/p/SP61870
That pic from Resto Country is wrong. Those 90 degree boots are for the male type cap terminals, they will not fit & Red V8 dissy. They even list them for a WB WTF ?
Dr Terry
#22
Posted 26 February 2023 - 03:27 PM
#23
Posted 26 February 2023 - 05:12 PM
Yeah I noticed the picture has the female ends for the big dizzy cap . But they are the ones I bought and have the correct male end but with right angle ends . So what brand do you recommend are the Bosch any good ? I couldn’t find any top gun ones with straight ends they all were right angle
Yes, the Bosch are pretty good but I believe they are also the most expensive.
Some of these resellers get a bit lazy & use generic pics that don't show the correct fittings.
When I get to work tomorrow I will get you correct pics & prices for all.
Dr Terry
#24
Posted 27 February 2023 - 12:31 PM
These are the Top Gun ones I got. If the Bosch ones are straight I might just get a set of them, Repco have 20% off this month . The right angle boots are nearly impossible to try and get right, I don't like the way you have to squash all the boots and leads together in the middle of the cap
Posted 27 February 2023 - 03:55 PM
I just had a look at my stock. The Bosch, PAT & Eagle leads all have straight ends & Top Gun have now changed to 90 degree ends, so they're going back.
90 degree are just a lousy fit on the small cap, only use straight ones.
Dr Terry
