Busted Trimatic
16 replies to this topic
#1 mdj
mdj
  • 47 posts
  • Car:UC Hatchback
Posted 31 March 2023 - 04:32 PM
Hi,
My traumatic has a fault where it fails to go into third gear and slips around, unless you back off the throttle and let it shift to third without any load. Stays in third just fine once it's in there, and if you drive her "manual" style the transmission feels like it is working fine.
Figured I'd ask on here before I commit to a rebuilt box if there's any chance of a simple fix ?
Cheers,
Matt
PS - be gentle I'm new here and to automatics in general.
#2 yel327
  • 13,575 posts
Posted 31 March 2023 - 04:51 PM
Not related to the problem. But is it a left or right shift Trimatic? If its a left shift like I have normally found in UC you have plenty of other newer donors up to VK to get one out of.
#3 mdj
mdj
  • 47 posts
  • Car:UC Hatchback
Posted 31 March 2023 - 05:04 PM
Good callout ... I'll check that out
#4 lemonaro
lemonaro
  • 47 posts
  • Car:lx hatchback
Posted 01 April 2023 - 12:08 AM
Sounds like a problem with the vacuum modulator or vacuum line between intake manifold and modulator.
Check modulator to see if any trans oil being sucked through the modulator up the vacuum line (its rooted if there is oil) then check the connection at the intake manifold, they have a tendency to clog up.
Check oil level when car is at operating temp also.
Edited by lemonaro, 01 April 2023 - 12:10 AM.
#5 mdj
mdj
  • 47 posts
  • Car:UC Hatchback
Posted 01 April 2023 - 08:58 AM
Thanks I’ll look into that … I wondered if since it shifts well under no throttle it might be a vacuum problem
#6 mdj
mdj
  • 47 posts
  • Car:UC Hatchback
Posted 28 April 2023 - 04:39 PM
So I dropped the pan on this thing finally to have a bit of look see. It jumped out at me that there is no magnet in the pan. That's gotta be bad right ?
Also there was a lot more of that gritty crap than is visible in shot as it was poured into my oil drum. Does this look like a terminal amount ?
The other thing was I managed to retrieve about 4 litres of fluid from the transmission before I dropped the pan. That seems like a lot to me, but I did park her on ramps for a while before jacking up the back so it was level so maybe a bunch of converter fluid drained to the pan.
This transmission slips like mad shifting from 2nd to 3rd but otherwise works fine. I was intending to clean up, replace filter, adjust bands, then check/fix the modulator and kickdown solenoid but does it look like it might be best to just rebuild it ?
Thanks,
Matt
Attached File  traumapan.jpg   180.01K   3 downloads
#7 yel327
  • 13,575 posts
Posted 28 April 2023 - 04:43 PM
They do take a fair amount of fluid. Transmission fluid isn't meant to be black - that is burnt and that much gunk, shouldn't be anywhere near that. My guess would be go looking for another transmission, you should be able to fine one OK for general use on Gumtree or similar. Get it checked/serviced before changing out.
#8 mdj
mdj
  • 47 posts
  • Car:UC Hatchback
Posted 28 April 2023 - 04:58 PM
The fluid look excellent to me - nice and red like Dexron should look. It's just the tiny bit left that slopped around in the gunk that's black. That stuff was more or less caked onto the pan until I started disturbing it.
#9 dron
dron
  • 128 posts
  • Name:Darren
  • Car:UC
Posted 28 April 2023 - 05:21 PM
With all that sludge in the pan of a slipping trans I would say it is rebuild time. They do not handel a lot of slipping. It kills the clutches real quick
#10 yel327
  • 13,575 posts
Posted 28 April 2023 - 05:23 PM
I'm not auto expert but I'd not be happy if my auto pan looked like that!
#11 claysummers
claysummers
  • 3,566 posts
  • Name:Clay
Posted 29 April 2023 - 10:50 AM
You haven’t said what engine this is behind. I have a 6 cyl left shift I need gone. From a VK injected 3.3, full bell housung.
#12 yel327
  • 13,575 posts
Posted 29 April 2023 - 11:52 AM
^^Grab that one if your is left shift. Just be aware of the speedo cable drive gear, it is likely to be the wrong one for a UC so you'll have to frig around to get the driven gear right.
#13 mdj
mdj
  • 47 posts
  • Car:UC Hatchback
Posted 01 May 2023 - 12:14 PM
Behind a 202 in a UC. I think it's left shift I'll have a look when I get home. What kind of condition are we talking ?
#14 claysummers
claysummers
  • 3,566 posts
  • Name:Clay
Posted 01 May 2023 - 01:16 PM
I don't honestly know the condition. I am asking $150. If you are nearby would be worth grabbing. If not then better find one near you. I am at Willunga SA.
#15 UCSLE
UCSLE
  • 703 posts
  • Name:troy
  • Car:Goggomobil
Posted 01 May 2023 - 02:28 PM
rebuild kits are not too expensive  https://www.ebay.com...ld kit&_sacat=0
#16 mdj
mdj
  • 47 posts
  • Car:UC Hatchback
Posted 01 May 2023 - 03:02 PM
I'm in QLD so a bit expensive to ship, thanks anyway. Local shop can rebuild mine for $1300 which is sounding like a fair deal.
#17 claysummers
claysummers
  • 3,566 posts
  • Name:Clay
Posted 01 May 2023 - 04:55 PM
Agree
