K-Mac rear sway bar to suit 9 inch diff
5 replies to this topic
#1 ellsie28
ellsie28
  • 75 posts
  • Name:Nigel Ellsmore
  • Car:911 Porsche, UC Torana Hatchback
Posted 07 April 2023 - 03:06 PM
Hi all,
looking for some help just bought a K-Mac rear sway bar to suit a 9 inch. Went to mount it up and found a couple of issues.
1. The spacer washers have the internal hole squared meaning they can’t be fitted the mounting bolt
2. My exhaust is in the way in mounting the pax side forward bracket.
anyone had these problems before and suggested solutions?
any photos of how other people have mounted theirs would be appreciated
thanks!
Nigel
#2 Cook
Cook
  • 1,523 posts
Posted 07 April 2023 - 03:54 PM
Hi Nigel. If you check out the tread "rear sway bar" (sorry I can't link it) or just google it you should find some good info and pics from ls2lxhatch. Cheers Ron
#3 ls2lxhatch
  • 5,332 posts
Posted 08 April 2023 - 01:17 PM
Quality control is non-existent at K-MAC.  It is not unusual to receive brackets with the holes punched in the wrong position or the wrong bolts and nuts to fit.
It sounds like you have the K-MAC UC style rear swaybar.
The Whiteline UV style rear swaybar may solve your exhaust clearance problems.
https://ls2lxhatch.com/suspension.htm
#4 ellsie28
ellsie28
  • 75 posts
Posted 08 April 2023 - 06:04 PM
#5 ellsie28
ellsie28
  • 75 posts
Posted 08 April 2023 - 06:14 PM
Yes mine looks like the top one.
The spacing washers inner diameter is too small for the bolts even after rounding the squared hole with a dremel. That meant a trip to Bunnings to get some washers to pack the brackets out.
unfortunately the attaching arm on pax side is fouled by the exhaust and a heat shield the sits on top of the muffler that attaches to the body. Looks like I have to drop the exhaust and notch the heat shield so it can clear the shield then create enough space by re positioning the muffler so it won’t contact the locator arm or the bushes.
thanks for the photos LS2LXhatch, much appreciated.
#6 Statler
  • 6,305 posts
Posted 12 April 2023 - 02:49 PM
Attached File  Purple swaqybar_zpsogreh4al.jpg   82.54K   11 downloads
I had no problems with this.
