BBQ-202 The Epic
#251
Posted 06 December 2007 - 04:03 PM
#252
Posted 06 December 2007 - 05:01 PM
#253
_LSmallmon_
Posted 06 December 2007 - 05:28 PM
My advice is to cut it out above the rust and get a piece of scrap metal for example like a old bonnet and cut out a size to fit it and bend and weld it in it is hard work but it pays off. Have fun mate it will look great when you finish it.
#254
Posted 06 December 2007 - 09:48 PM
Or as I have said I the past, some of these so-called panel beaters should be called Michelangelo for their sculpting prowess with bog.This bloke is a plastic surgeon by trade, or so he tells us...
#255
Posted 06 December 2007 - 10:24 PM
HAHA yeah i was just joking! Cos its something that Heath would have said if i put a pic of my car with bog on it! hahaI have to stress that there isn't actually particularly much bog on it, I think Matty was just joking. He hasn't seen it in the flesh and you can't see much in that shot I provided... I'll get some better photos. There's nothing over a few mm really, I would say that way more than half of that bog has been sanded off Rob, but I may be wrong.
I think that if you apply bog and the car looks straight, the paint sticks and you have no hassles then the stuff is bloody fantastic! if its done wrong then it can make big problems!
#256
Posted 07 December 2007 - 01:33 AM
A door skin was used, took about 3/4 of an hour to weld inMust be common to have the bottom of the rear guards to rust out mine was the same on the left hand side.
#257
Posted 07 December 2007 - 12:29 PM
#258
Posted 07 December 2007 - 12:56 PM
#259
#260
Posted 07 December 2007 - 02:00 PM
Was that a fore door skin?my doorskin hasn't been cut.
#261
_Herne_
Posted 07 December 2007 - 02:11 PM
Herne
#262
Posted 07 December 2007 - 02:33 PM
I'm feeling tired... me and a mate worked on the car til like 11pm or something last night and now I am lacking energy and motivation.
Waiting for bog to dry atm *sigh*
Tomorrow I will have a semi professional assistant.
#263
_L31SS_
Posted 07 December 2007 - 02:58 PM
Keep persisting, look forward to seeing some more progress photos.
#264
Posted 07 December 2007 - 08:34 PM
how did you go about bending it to shape? im still tossing up whether to cut some out of mine or not... only has very slight holes, although its quite thin with the rust from the inside...A door skin was used, took about 3/4 of an hour to weld inMust be common to have the bottom of the rear guards to rust out mine was the same on the left hand side.
My advice is to cut it out above the rust and get a piece of scrap metal for example like a old bonnet and cut out a size to fit it and bend and weld it in it is hard work but it pays off. Have fun mate it will look great when you finish it.![]()
more pics heath!!
#265
Posted 07 December 2007 - 08:41 PM
You need a Range Rover tail gate but you might be able to use a Hi-Ace rear floor opening.how did you go about bending it to shape?
#266
Posted 07 December 2007 - 08:49 PM
As requested:
#267
Posted 07 December 2007 - 09:06 PM
i take it from that comment by rodomo that you didnt use any high tech tools?
cheers for the snaps!
#268
Posted 07 December 2007 - 10:23 PM
I'll be using finer stuff from now on though. The really course grades are only for things that need a lot of shaping. Using very course paper creates difficulties...
That body file and a smaller block as well
Edited by Heath, 07 December 2007 - 10:25 PM.
#269
_SLR Goat_
Posted 08 December 2007 - 01:57 PM
#270
Posted 09 December 2007 - 11:21 AM
#271
Posted 09 December 2007 - 11:33 AM
#272
_gtrtorana_
Posted 09 December 2007 - 07:15 PM
#273
Posted 09 December 2007 - 08:15 PM
is there a torana under all that bog?
thats a bit of bog!
sounds like there's a bit of bog going into this car
Lol got bog?
Thats some serious bog !!!!
I know that at least Matt didn't have bad intentions but am I supposed to not be offended by this kind of shit?
Is it just me or is everyone speaking to me like I'm doing some #@$^%& up full bogan spec repair job on this car? The filler work I have done on this car covers large areas so it is less likely for little spots to crack off, I beat everything out as best I can before I apply any filler. None of the people who said those quotes have even seen the car in the flesh. None of it is thick or rushed or anything in my opinion to be worse than the execution which would be done by most members of this forum, but the majority of the people here would just send their car off to the 'panel shop' to be straightened out and painted. I am taking my time on this car and working my arse off for hours every day, and you all seem to think that I am just filling the vehicle with bog because i can't get off my arse and do it "properly" or something.
This car needs the repairs to be done with filler, they can't be beaten out and file finished, especially when I don't have a set of dollies, spot welder and oxy. f*ck can you please at least watch what you say? There's no point in me going out of my way to share progress on my car with others if they are just going to insult the best I work I can do.
My car is not full of fvcking bog, it is just applied over large areas so that the panels end up f*cking straight, not just a few patches over the deep dints.
This is something I would NOT do. That was >6mm in the middle and this guard is going in the bin.
Edited by Heath, 09 December 2007 - 08:15 PM.
#274
Posted 09 December 2007 - 08:23 PM
Your acting like a BOGan!
How much for the guard?
#275
Posted 09 December 2007 - 08:30 PM
