Suspension will be lowered but not too stiff or anything, I still want it to be a comfortable cruiser, but I'm not too concerned about getting the rear end to hook up
Arches will be pumped a little bit hopefully (shortly), I will keep you posted on whether that is still happening...
Wheels are fat chromed stockies wrapped in Eagers.
Motor will be the 202 that is in the car atm, but I'm collecting parts for it to be a bit hotter... cam, head that needs some work, Redline Roadmaster V2 manifold, Weber that I am going to replace with a bigger Weber, Double Valve Springs, Full exhaust etc... that's all lying around the house but it will all be upgraded in a few yrs when I build a more serious 202 from a HP block I've got in the shed.
MC6 and Banjo will do for the time being, but I'm getting an R31 diff shortly which I plan to get made to suit the LX and run a 3.45 LSD 28 spline jobbie in, and a Falcon 6cyl Tremec T5 would be an ideal gearbox to match that diff later on down the track... that will be matched to the hotter motor though, not the crappy cheap 202.
And yes I haven't been doing updates because the stuff I am doing is boring as batshit. It doesn't look like I'm doing anything in photos
But I will get more shots, thanks for the encouragement guys. I'm gonna have brekkie and get to work
