BBQ-202 The Epic
#51
Posted 19 September 2006 - 12:27 PM
#52
Posted 19 September 2006 - 06:42 PM
...he even suggested converting to UC tail lights
Someone else was jealous of the attention the Torrie and a tenth were getting, and decided he would join in the photoshoot
...stop moving!
That's better.
And I am still wanting to look at any Toranas being cut up, because this section is far from perfect, but at least it gives me a bit to work with.
Does anyone wanna guess who the unexpected guest was? hehe
Edited by Heath, 19 September 2006 - 06:44 PM.
#53
_73LJWhiteSL_
Posted 19 September 2006 - 09:08 PM
My vote is Chopper.Does anyone wanna guess who the unexpected guest was? hehe
Steve
#54
Posted 19 September 2006 - 09:10 PM
If you read this, thanks Chop!!! Will save me some cash which could be put to better use...
Edited by Heath, 19 September 2006 - 09:11 PM.
#55
_chevy_253_torana_
Posted 19 September 2006 - 11:54 PM
christ i have followed heaths footsteps i can rememeber doing the lj last summer with the wire wheel in the drill no mask in the middle of the day doing it for over an hour sometimes it went for a few minutes as well ...
one day il rememeber the masks !
Edited by chevy_253_torana, 19 September 2006 - 11:58 PM.
#56
_CHOPPER_
Posted 20 September 2006 - 06:54 PM
#57
Posted 20 September 2006 - 07:26 PM
#58
_@milco@_
Posted 20 September 2006 - 09:47 PM
#59
_chevy_253_torana_
Posted 20 September 2006 - 10:11 PM
trust me if i had my own lighted shed i would probably be up there all night and live there basically.
#60
Posted 21 September 2006 - 01:33 PM
More good news:
My school does have a mig welder that I can practise on. Once my solar car is finished (comp is in just over three weeks time), I'll be in the metaltech room every day and every free period learning to weld. Still don't know what welder I'm actually going to use on my car though... but it's better than not having any access to a welder full stop.
#61
Posted 21 September 2006 - 01:38 PM
#62
Posted 21 September 2006 - 03:40 PM
Anyway, back out to the car.
#63
_youngy_11_
Posted 21 September 2006 - 03:46 PM
#64
Posted 21 September 2006 - 04:52 PM
Should I continue washing my hand? Or pull the front screen out top?
#65
_73LJWhiteSL_
Posted 21 September 2006 - 05:32 PM
Steve
#66
Posted 21 September 2006 - 07:44 PM
I'm still surprised I managed to get the window out myself actually. Last time Chopper gave me a hand, and people have told me that it's impossible to do without two people, but yeah it worked out fine, maybe Torana rear windows are just easy compared to most windows? I feel proud of myself
Edited by Heath, 21 September 2006 - 07:45 PM.
#67
_CHOPPER_
Posted 21 September 2006 - 07:46 PM
#68
Posted 21 September 2006 - 08:06 PM
The pics make the rust look worse than it is; it ain't bad at all. Bit of fibreglassing will do the trick, if that!. I just hope putting windows in isn't hard.
Edited by Heath, 21 September 2006 - 08:07 PM.
#69
Posted 21 September 2006 - 10:48 PM
When you get yr pop's 4" grinder, go to Bunnings and get the 1mm cutting discs. Cuts like a knife!
Edited by rodomo, 21 September 2006 - 10:52 PM.
#70
Posted 21 September 2006 - 10:51 PM
#71
_lurkin308_
Posted 21 September 2006 - 11:09 PM
#72
Posted 21 September 2006 - 11:28 PM
_Yella SLuR_
Posted 25 September 2006 - 07:53 PM
Personally, cut out and weld in as little as possible, as it just creates more work. Use Mig to spot weld on some screws at try pull as much of it out with a slide hammer as possible (screws will pull off if lightly spotted, but that's normal).
Same with grinder, manage the heat, don't work one area intensely. Metal should be cool to touch at all times after grinding/sanding. Slowly slowly catches the monkey.
Need to do the same repair on the race wreck on the bottom rear quarter. Will try take some pics. I'm forming up my own replacement panels.
Other basic tools you will need are body file, and speed file (long flat sandpaper thing).
Edited by Yella SLuR, 25 September 2006 - 07:54 PM.
#74
Posted 26 September 2006 - 09:20 AM
Is that just a long block with course sandpaper stretched over it?speed file (long flat sandpaper thing)
That would be very helpful, thanksNeed to do the same repair on the race wreck on the bottom rear quarter. Will try take some pics
And yes, I want to try with an old body panel (cutting it up then welding it back together presentably) after I learn the basics at school next term.
Cheers Pat
#75
_CHOPPER_
Posted 26 September 2006 - 10:39 AM
Like the one I dropped around, or are you talking about your parents?And yes, I want to try with an old body panel (cutting it up then welding it back together presentably) after I learn the basics at school next term.
