BBQ-202 The Epic
#126
Posted 27 January 2007 - 10:32 AM
in saying that dont ever wear gloves on a bench/pedestal grinder.
the speed and torque from one that catches clothing will pull you into the grinding face.
if any person uses a wire wheel fitted to an angle grinder for stripping paint rust etc PLEASE tuck your shirt in(sounds like high school i know).
the air suction created by the wheel has a habit of pulling loose clothing into the wheel and then the grinder will bind itself to your stomach flesh.
you wont stop a decent grinder wwithout pulling the plug.
#127
Posted 27 January 2007 - 03:46 PM
Heath, good to see you wearing safety glasses and ear muffs too.
I should have mentioned you hadn't totally disregarded your own safety.
Rim, it doesn't take long to put on some safety gear and you just could be saving an eye or fingers or some hearing loss. If you have some gloves which are comfortable and fit well, they won't effect your workmanship.
I know in our previous generations safety was pretty much non existant. But be smart about it and don't put youself at risk. Have a word to your Dad and try and break his bad habits instead of following them.
I've seen the results of some nasty accidents, and they're not pretty. Kind of sticks in your mind when going to use these power tools.
Be smart and look after yourselves!
#128
Posted 27 January 2007 - 04:04 PM
RIM
#129
_ChiaLX_
Posted 27 January 2007 - 06:00 PM
Well done in tackling what I consider a major job. Something that most people here would not attempt themselves, so be proud.
#130
_racyrabbit_
Posted 28 January 2007 - 09:46 AM
#131
Posted 28 January 2007 - 09:58 AM
no a pretty site, and then i had to take him to hospital, he is permenatly scared and also has a limp
Edited by boomfunk, 28 January 2007 - 09:58 AM.
#132
Posted 28 January 2007 - 10:04 AM
#133
_LH SL/R 5000_
#134
Posted 28 January 2007 - 10:21 AM
RIM, I never implied you didn't wear safety glasses and ear muffs, just add some gloves to your safety gear mate.
#135
Posted 28 January 2007 - 10:24 AM
the only 9 inch worth having is under the car.
#136
Posted 28 January 2007 - 10:37 AM
You've certainly jumped in to the deep end..."Bite of more than you can chew, and chew like hell!"
Getting the results there mate, well done!
Sorry I can't help, I've never done bodywork, although you don't seem to need much help, you're doing great!
Keep the updates coming.
#137
Posted 28 January 2007 - 10:54 AM
Or in the bedroomthe only 9 inch worth having is under the car.
#138
Posted 28 January 2007 - 11:48 AM
#139
Posted 28 January 2007 - 12:11 PM
My sunbird would still be a complete vehicle if it weren't for Rick's 9" Grinder. Man that thing was a serious weapon.
#140
_Monkey_
Posted 28 January 2007 - 12:17 PM
Rick's 9" Man that thing was a serious weapon.
#141
Posted 28 January 2007 - 12:37 PM
#142
Posted 28 January 2007 - 12:43 PM
#143
Posted 28 January 2007 - 10:55 PM
Finally found a use for UC parts and panels! use them to fix LX's!
#144
Posted 28 January 2007 - 11:14 PM
haha onya mate!
#145
Posted 28 January 2007 - 11:16 PM
chop chop
#146
_torana_
Posted 29 January 2007 - 03:46 PM
As well, if using a drill and you have long hair, dont let it get wrapped around the chuck, Ive seen that once before and its amazing what a 2inch square of scalp looks like once the hair has been removed and hasnt quite started to bleed yet.
cheer julian
ps: keep up the great work heath
#147
Posted 29 January 2007 - 04:29 PM
I never cut with grinding discs, but I sometimes grind with cutting discs.
I also have short hair.
#148
Posted 04 March 2007 - 05:00 PM
Most importantly, i'd like to thank Rob (Rodomo) for not only teaching me how to weld on his car, and giving me heaps of other incredibly useful information, but then going even further out of his way by coming over to my house multiple times with his equipment to slave away at my rusty, mis-aligned project. I'd be stuffed without you mate, thankyou very much!
Since the last update, the back of the car has recieved a bit of a bootlid-gap on the LHS (well, in two ways, as you'll see in the photos; one bad, one good), and it has been aligned a lot better than it was previously.
Now, what everyone has been waiting for... PHOTOS!!!
What she looks like at the moment pretty much:
(dunno why i took them from different angles, they were taken like a week apart from each other, so i musta been in a different mood, and I cbf opening photoshop again)
My welding, raw:
Cleaned up with the wire brush:
Guess who?
That area currently...
Just before it got dark I grabbed the mig and filled in the holes on the bootlid:
Ground down later on.
Man I need more time. I wanted to do a shitload of work today, but I only got to do about a sixth of what I expected lol. Too many distractions and things just taking ages.
I also bought a $70 orbital sander with a 5mm offset (if that's what you call it; how it wobbles as it spins) and that's working brilliantly; but once again, no time to use the damn thing!
All I got done today was some cleaning up of the floorpan area on the driver's side. Lots of Wire brushing, Rust-Killing, Sanding, and painting with sound deadener.
Ready for paint:
Drying:
Edited by Heath, 04 March 2007 - 05:06 PM.
#149
Posted 04 March 2007 - 05:51 PM
I'm goin home this weekend, hopefully get a bit more filling and stuff done.
Keep it Up.
Tim
#150
Posted 04 March 2007 - 06:00 PM
Look forward to your updates buddy.
