BBQ-202 The Epic
#1601
Posted 05 March 2010 - 10:17 AM
#1602
Posted 05 March 2010 - 10:20 AM
#1603
_mello92_
Posted 05 March 2010 - 02:17 PM
#1604
_doogs_
Posted 05 March 2010 - 04:37 PM
#1605
_mick74lh_
Posted 08 March 2010 - 08:40 PM
#1606
_BlownOutlaw_
Posted 11 March 2010 - 10:37 AM
Did u just de-grease and sand back? or did u use a paint stripper or ?
Same with the K frame?
#1607
Posted 11 March 2010 - 02:08 PM
Takes a while lol
Got my rebuild kit for the centre now too.
Edited by Heath, 11 March 2010 - 02:09 PM.
#1608
Posted 17 March 2010 - 12:36 PM
This is the whole centre assembly as I pulled it out of the diff housing. Had course side gears, and the gearset wasn't in the best condition anyway. Bearings were noisy too. 3.36 ratio if I didn't mention it in an earlier post:
Centre out:
Pinion out:
Centre apart:
Comparison of side gears, fine and coarse spline respectively. Using fine:
New gearset in:
Ready to put it back together at home with a 'rebuild kit' from Bearing Wholesalers (bearings and pinion oil seal)
Replaced the standard crush tube with a non-compressible tube,
...toleranced to suit this housing and these bearings. This is just turned up on a lathe out of MS, takes a bit of buggering around to get it the right length though. Anyway this allows you to control your preload properly, and absorbs the forces that occur when the helical gearset (pinion & crownwheel) try and go in and out of mesh (i.e. when you come on and off power assuming that you actually have a man's gearbox, or whenever you go to reverse etc). This one has about 3 thou of preload and it means you do the nut up as tight as you can get it, which is where tools shown shortly come in handy
This photo just shows centrepunched marks on the pinion shaft and the yoke - just keeping them in the same relative position:
Tools that assist in applying proper torque to the nut: lol
Not finished yet though...
#1609
_doogs_
Posted 17 March 2010 - 02:27 PM
I'm assuming Rob has convinced you not to go for the spring locker setup ?
Love this quote, nicely said.assuming that you actually have a man's gearbox
#1610
Posted 17 March 2010 - 02:37 PM
#1611
Posted 17 March 2010 - 03:28 PM
...assuming that you actually have a man's gearbox...
All you need now is a Man's motor running on some Man's fuel!
#1612
_ass308_
Posted 17 March 2010 - 03:31 PM
#1613
Posted 17 March 2010 - 03:38 PM
I'm assuming you checked out the tolerances in the spider/side gears and they are all good, along with the centre pin? Seeing as you've gone to the trouble of all new bearings and solid spacer it would be a shame not to cover everything
Good setup with your 'tool', you need something like that even with collapsible spacers as they take a lot to compress
#1614
Posted 17 March 2010 - 04:18 PM
I had a 3.08 Fine Spline Salsbury? Carrier that I got the gearset out of. So I had two pins and used the pin that had the largest diameter on the contacting surfaces, and the best looking gearset of the two, with the fine spline side gears. What do you mean by tolerances of those gears? Sticking a feeler gauge in the mesh or something? Because I didn't go that far.
#1615
Posted 17 March 2010 - 08:12 PM
#1616
Posted 17 March 2010 - 08:25 PM
#1617
_doogs_
Posted 17 March 2010 - 10:47 PM
Yeah kinda, I dunno I might try it later on as a spare centre. If it doesn't work well it hasn't cost me anything so no big problem. Are you going to get one for yours?
I'm thinking about it, but Ross has almost convinced me to just wack a Celica diff or similar under it with an LSD. Him and Stew don't like the idea of a "poor mans LSD". Will see how funds go for starters.
#1618
Posted 18 March 2010 - 05:44 PM
#1619
_AD_75_
Posted 18 March 2010 - 05:47 PM
Righto I'll admit it, it's a "lot of effort for a Banjo". But I've learnt shitloads doing this and it has been good fun. I got heaps of photos of doing all this stuff if anyone wants to know about anything let me know. I'll post a fair few up anyway though
Haha all good
#1620
Posted 18 March 2010 - 05:48 PM
#1621
Posted 18 March 2010 - 06:03 PM
#1622
Posted 18 March 2010 - 06:34 PM
#1623
Posted 18 March 2010 - 07:14 PM
Most Holden manuals work on 3 notches to set the preload so you should be good with that
#1624
Posted 18 March 2010 - 08:50 PM
#1625
Posted 18 March 2010 - 10:39 PM
