Well it has been a while...
I've been doing a lot of k's in the car and it's a bit sad so I thought it was about time I get my arse into gear and give it some love. I've made a pretty considerable list of things that I want to do on it but they will all take some time and money.
One of the items was sorting out the front end. It has never had a swaybar because it doesn't have the holes in the crossmember and the extractors that are installed are really bad for clearance and won't actually allow one to be fitted, the bushes were never much chop, and it never sat nicely (left to right or front to rear). On the weekend I put it on the hoist and spent so much time working on it, and didn't get everything I wanted to do done, and ended up lowering it far too much. Miscalculated some stuff and ended up with a car that looks pretty stupid and is ridiculously impractical. Anyway, here's the pics
How I left it when I first changed the springs ages ago:
After much stuffing around lifting the car off its crossmember, I got the top arms off:
Gave it a clean up before sandblasting
Then gave them a coat of some KBS chassis black paint I bought. Not many distributors that I know of in Melbourne, I got mine from Heritage Holden in Lilydale and I'm really impressed with the product. Similar to POR15 apparently but I've never used that product.
I tried using an adjustable spreader tool on the arms first but I didn't like how it was going. Still tried to bend the arm awkwardly and brought the centres too close to each other. I then over-extended the spreader tool to get the arm back to how it was and got the pipe etc to press it in a way that I thought was far superior.
Pressing the first bush in:
Pressing the second bush in: (tricky because of the cast pivot arm obviously)
And the final result of lowering it about twice as much as I wanted.
Next step is raising it up a bit, getting a good wheel alignment. Then replacing my exhaust with something that has some clearance and fitting a front swaybar. When I've done all that I might pull the motor out.
