BBQ-202 The Epic
1886 replies to this topic
#1701 _ToranaGuy_
_ToranaGuy_
Posted 19 August 2010 - 05:21 PM
Nice progress Heath! It's been a while since I've stopped by to have a look, but I'm impressed. The ride height looks good in the pics, but when you have a sway bar fit it will probably be too low. Pitty. I found my pedders red 40mm lower springs are probably the limit of how low I'd ever want to go in the torry.
ToranaGuy
#1702 _Torrie_Man_
_Torrie_Man_
Posted 19 August 2010 - 07:30 PM
Youshould of chucked in some rubber bushes! those urethane ones are nothing but trouble!
#1703 _gen3torrie_
_gen3torrie_
Posted 21 August 2010 - 11:06 AM
KBS all the way
#1704 Heath
  • 18,393 posts
Posted 21 August 2010 - 01:03 PM
Just because some people got bad batches doesn't mean that all the advantages of more solid bushes are abolished. I made an educated decision to use a urethane bush. IIRC rubber bushes were marginally cheaper.
I pulled the car apart again yesterday and raised the front. I left the hub assembled, left the steering arm on and everything, adjusted some springs and dropped the top ball joints and installed them. You can do this without too much trouble BUT you need to go full lock one way to get the spring out, then hang the setup back up by starting the nut on the upper ball joint, go full lock the OTHER way and then work on the opposite side. With the springs I installed in the car last weekend, I could get the nuts on both balljoints BY HAND i.e. no jack or spring compressor required lol. These ones took an internal spring compressor to seat them and a jack to preload them to get the balljoint nut on.
The result of the work is that I got it sitting with 290mm between the hub centre and the wheel arch on all four corners with a 70-75kg bloke in the driver's seat (i.e. me), so that is sorted how I wanted it, BUT now I have a noise coming from the right of the front end and I don't know what it is. I retorqued it all a second time at ride height but the problem hasn't gone away. I'm just going to persist and hope that karma owes me some success with my car, as I want to drive it up to Rob Roy tomorrow for a historics event but at the moment I'm scared a balljoint is going to pop out or something!
#1705 rodomo
  • 18,038 posts
Posted 21 August 2010 - 01:09 PM
Check to make sure the spring is seated correctly.
#1706 Heath
  • 18,393 posts
Posted 21 August 2010 - 01:16 PM
Well how far out would it have to be to make a noise? I made sure that all I could see through the little pin-hole (i guess it's a drain hole) in the spring cup area of the lower arm was the spring coil hard up against it. But that is the type of noise it resembles. Gotta say though (lol), I was driving around with springs that weren't seated properly for over a year and there were no problems like this. Ohh god I can't believe I just said that on a public forum
#1707 Heath
  • 18,393 posts
Posted 21 August 2010 - 05:40 PM
Well it's got me f'd. I've torqued everything up at ride height twice now. I tightened everything up a little tighter. I cut a shim to sit behind the nut on the upper balljoint of the side making the noise, because I was a bit worried there wasn't enough preload on the taper (I find the castle nuts frustratingly coarse in their adjustment). Took it for a drive to a mate's place and it didn't make a noise. But when I pulled into a servo on the way back, it was clear the noise hadn't gone. It may have reduced though? Only thing I can think of is pulling the shocks out and taking it for a drive and seeing if the noise goes away.
#1708 MRLXSS
  • 12,414 posts
Posted 21 August 2010 - 06:17 PM
What type of noise is it making? A knock, a squeek or something else?
Sometimes it can be seated ok at the bottom, but on the top it might be a funny angle and rub on the sides. Maddy's UC daily did it, had to put the springs in again and it fixed the problem... bloody annoying! I can tell you that.
#1709 76lxhatch
  • 7,205 posts
Posted 21 August 2010 - 09:29 PM
I've had springs that move around just a little even when seated correctly (nothing dangerous and they don't go anywhere), they generally quiet down after a bit. Perhaps get it up on ramps or a hoist when you can safely get under it while someone pushes the suspension around and see if you can pinpoint the noise. Don't try driving it without the shocks.
#1710 LXCHEV
LXCHEV
  • 3,610 posts
  • Car:'76 LX - 383 Chev
Posted 21 August 2010 - 09:38 PM
At a minimum, remove the shock, and then have a look up and see if the spring is seated at the top. At least that's just a quick easy check.
#1711 _mick74lh_
_mick74lh_
Posted 22 August 2010 - 05:39 PM
I'm guessing you've jacked a corner of the car up and grabbed the wheel top and bottom to check for play in the ball joints or wheel bearings?
Are you sure the shock is properly done up top and bottom? I remember once following Brad down to Inverloch in his Torry and he kept saying that the front end was knocking. Turns out we'd forgotten to do up the top nut on one of the shocks. Couldn't bloody believe it!
I know these suggestions may sound kinda stupid but its always the little things that get ya.
Maybe make up a second shim to go under the ball joint castle nut. Hope you can sort it out no worries.
#1712 _Bomber Watson_
Posted 22 August 2010 - 06:03 PM
Just put a set of camira springs in the back, along with the dumbly low fronts you just took out. Will solve all the current problems.
#1713 _Brad1979UC_
_Brad1979UC_
Posted 23 August 2010 - 10:06 AM
Hahah a while ago but yea, the top of the shock was hitting the wheel arch :o. Was pretty loud. You know it's most likely going to be something stupid like that haha.
#1714 Heath
  • 18,393 posts
Posted 23 August 2010 - 05:02 PM
lol yeah I've checked everything I can think of that could be a significant thing. If the spring is just turning a fraction as the transient load does its thing, that's fine. It seems to be shutting up anyway after giving it some stick over some speed humps
Sanded back the roof today and manually polished it... doesn't look that great yet. Plenty of elbow grease required haha
#1715 _mick74lh_
_mick74lh_
Posted 24 August 2010 - 08:27 PM
See if you can get some Auto Glym Paint Renovator and the same brand Super Resin polish. I've had good success on cars other than my Torana manually polishing with that stuff. Apparently it doesn't contain silicone and i wish that it was all that i used on my Torry when i painted it but ah well. I can give you a hand on sunday if you want. Should be able to get the roof and the bonnet looking tip top.
Have you only used 1200 grit wet to sand the roof? Cos I that's what i'd advise. I reckon 800 is too course.
#1716 rodomo
  • 18,038 posts
Posted 24 August 2010 - 11:58 PM
Sand blast and start again.
#1717 Heath
  • 18,393 posts
Posted 25 August 2010 - 10:38 AM
800-1200-2000 then polish but I do wonder how well the really fine wet paper actually works with acrylic paint. I think I need to get my hands on some higher quality polishing products. I'll give you a call Mick
#1718 Heath
  • 18,393 posts
Posted 25 August 2010 - 06:42 PM
As per Mick's advice, I bought myself some Auto Glym stuff (I could have spent about $500 with all the products they had available) and had a little play with it; far better results. Tomorrow he's gonna come around and lend me a hand for a little bit and share advice etc. Should be good
I swapped my alternator over as well today. Old one was making intermittent bearing noise and charging at 13.8V @ warm idle, this replacement is providing 14.1V @ warm idle so it should be good. But I'm tempted to rebuild one at some stage, or perhaps upgrade to one with a higher amp rating if I get bored. Enough things on my plate at the moment but it feels good ticking a problem off the list.
#1719 _mick74lh_
_mick74lh_
Posted 26 August 2010 - 12:22 AM
Is that the alternator you pulled out of the VN sitting across the road? If it is, you're a funny guy!
#1720 Heath
  • 18,393 posts
Posted 29 August 2010 - 08:25 PM
lol it isn't that alternator, just from another Torana. And since replacing the alternator, I have realised that a noise that I thought was alternator bearings is actually (perhaps in addition to) a problem with the extractors sitting close to the engine mount and occasionally vibrating against them. No biggie because they are getting replaced soon anyway, just gives me more reason to do that soon.
Matt, in response to your comment. This is how low the car was:
lol
This is it fixed:
Yesterday I took the car in for a wheel alignment. The third time I've paid someone to do work on my car. After buggering around with the upper arms and putting them on left to right (they are theoretically symmetrical - not UC arms - just obviously distorted a bit from braking forces I dare say) it was pretty clear I had some negative caster, and I could see the toe was up the shit because of the tie rod angle after altering the ride height. Good thing I didn't piss fart around or I would have stuffed a pair of tyres haha
So yeah, a bit of toe-in (which I can easily adjust myself if I want to follow 76lxhatch's advice), some positive caster and negative camber (all around lol half a degree on the rear wheels wooo!)
So that and the polishing overall puts me in a position where I am pretty happy with how things are with the car. Because I was so happy with the car, I took it down to a car show in Narre Warren today at the Retro Speed Shop (where I organized to meet BlownOutlaw too as he was in Melbourne today)
And to avoid confusion, I should say that no that isn't his car, just one that parked next to me at one point during the day - his is still in the works :)
Edited by Heath, 29 August 2010 - 08:28 PM.
#1721 Heath
  • 18,393 posts
Posted 29 August 2010 - 08:38 PM
Ohh yeah and on the way home I went through an industrial area and got myself some photos that I think are alright. I borrowed my friend's Lumix - it's just a bridge of some description and just did some really basic editing in Photoshop
#1722 MRLXSS
  • 12,414 posts
Posted 29 August 2010 - 09:27 PM
Great Stuff Heath! The new ride height is better than before... That side shot shows how silly it was... Especially being on 13's...
#1723 _@milco@_
_@milco@_
Posted 29 August 2010 - 10:42 PM
damn mate it's lookin' pretty good....i am lovin' the industrial shots...
#1724 _doogs_
_doogs_
Posted 29 August 2010 - 11:52 PM
Nice pics Heath, good to hear you managed to get the alignment in too.
#1725 _ToranaGuy_
_ToranaGuy_
Posted 30 August 2010 - 07:05 PM
Heath! Man that torry is looking the goods now, nice work on the photo shoot too, come out really well!
Keep up the good work.
ToranaGuy
