Hi Dave,
I couldn't find the H1158C Filler Neck Kit, came up with H1474 which is the neck only. If you have a standard neck I believe you can use it, just needs to be shortened slightly. You will also need a H1003 Hose kit if you haven't already got those parts and the SU1008NE kit you mentioned.
The Tank Sender Unit fitting tool has been reproduced and is readily available on eBay from several suppliers- not cheap, and all flogging it at the same price ($169.99) for something you may only ever use once. I have fitted a sender without the tool before- it is a bit of a PITA to do, but $170 buys a few slabs! You may be able to con someone local to loan you there's for some beer?
https://www.ebay.com...:Bk9SR9iz64qnYg
Brad Merrick reproduces the vent pipe to order ($220 according to his website), but you have to collect it from over here as it's too big to courier. The mounting clips (3) on the other hand are a different story and virtually unobtainium :-(
https://www.xu-1.com...boot_parts.html
As you will see in the link, he does the vinyl cover and boot mat as well.
Otherwise it's all pretty straight forward.
Cheers,
Richard
Edited by jpxu1, 09 July 2023 - 01:54 PM.
