Stripped thread in torque converter
2 replies to this topic
#1 mdj
mdj
  • 47 posts
  • Car:UC Hatchback
Posted 30 July 2023 - 04:19 PM
Hi
As the subject says ... late 6 cylinder trimatic in a UC ... crossed one of the bolts getting it in and now seem to have stuffed the threads in the converter mounts ... can't reach tightening torque - they go "ping" and let go :-(
Any suggestions ? Don't have an extra set of competent hands til at least next weekend to help drop the box again. Was thinking I could try a helicoil and some locktite but am a bit wary considering what the bolts are for ...
#2 yel327
  • 13,575 posts
Posted 30 July 2023 - 05:54 PM
These are a blind thread into the converter body? Or captive nuts on tabs? If they are captive nuts you could try and right angle drill the thread out and use a nut on a bolt. Just make sure the bolt is the right grade. Otherwise pull the box out and go from there. Are you sure you have the right bolts?
#3 mdj
mdj
  • 47 posts
  • Car:UC Hatchback
Posted 30 July 2023 - 06:48 PM
Just threaded into a boss in the 'riser' as far as I can tell - it's hard to see on the late trimatics without the cutaway bellhousing.
They are the right bolts - got a fresh set from a wrecker as I stripped one of them and wanted three matching. They're what looks like a UNF thread on a 5/8" or 11/16" head.
