Good summary mate,
Seems that most of us play with these old holden 6s is the challenge of getting N/A power rather than buying a 500hp crate motor for less than spent on a fancy holden 6 head... Some of the topics I raised above in this thread seem to be directly related to this, even though more about fixing up efficiency losses for a mild street car rather than max N/A power. Still curious to hear others thoughts on their measured lifts vs theoreticals.
For the fuel injection, yeah at wide open throttle (engine at operating temp) the engine needs a river of fuel and not a fancy mist. However the fanciness that comes from controlling the fuel timing is advantageous for driveability in a street driven car, for improved cold starts, injecting after valve overlap events at low revs (not shit it out the exhaust) and being able to easily tune out flat spots etc. Once again depends what you are trying to achieve here and if an all out drag car than prob not.
Just for the closing of the inlet valve comment, I know what you are trying to say mate and I'm sure you already know this and were trying to say this. Just if the bore is already filled, the piston coming back up with the inlet still open and you have some inlet air inertia still flowing and ramming air in at slightly higher than N/A pressure, then that's what should determine the inlet valve closing time. Really requires tuning your cam timing to your inlet manifold dynamics.
Also seems if you have a large overlap cam and evacuating the exhaust too early can be detrimental to making use of the scavenging event. This would be at the expense of some reversion into the inlet manifold at low revs. I'm keen to get more lift on my inlet here to take advantage of the flow my head still has in it but maybe not on the exhaust as the percentage of flow between the inlet and exhaust is already pretty high. I can see in my manifold I have a little reversion going on at the moment but the ITBs and fuel injection seem to handle this fine with not having to have a high idle speed.
Yeah I could probably choose a better cam and chuck it in (less agricultural) but maybe after I have eventually tried out some 1.7 or 1.8 rockers etc and then actually do some testing on a dyno to see what's improved.
Before new rockers, first going to try an off the shelf 5/16 9.05in pushrod with a .110in, 210deg ball wall to see if I get any of my theoretical lift back from a) lose one turn out of the rocker adjuster and maybe slightly better rocker geometry
less deflection with the thicker wall c) bees dick better geometry on the pushrod side from different angle ball. As previously mentioned if you guys think i should go down to custom 0.025in pushrod increments here please let me know.
Then after that I finally get around to measuring the clearance I have from the valve to the bore walls and thinking about 1.7 or 1.8 rockers for a trial, if i stick with the same brand rockers then there should be a relative increase in ratio rather than two different manufacturers having differences between their stamped ratios.
Thinking I should base my clearance from valve to the bore wall here of my larger theoretical value rather than the lower actual value for caution.
Bruiser you may like this article also.
Edited by Liam Kelly, 25 August 2023 - 10:45 AM.
