lx torana brake booster
24 replies to this topic
#1 marko1au
marko1au
  • 207 posts
  • Car:LX sadan
Posted 09 September 2023 - 08:53 AM
does it matter if you mount the booster 180 degrees from original ........ vacum inlet on the left hand side of the firewall
                      Mark
#2 Uncle Chop Chop
Uncle Chop Chop
    Grumpy Old Man
  • 1,409 posts
  • Name:John
Posted 09 September 2023 - 10:02 AM
As in, mount it upside down?
#3 marko1au
marko1au
  • 207 posts
  • Car:LX sadan
Posted 09 September 2023 - 12:28 PM
yes mount it upside down
#4 UCSLE
UCSLE
  • 703 posts
  • Name:troy
  • Car:Goggomobil
Posted 09 September 2023 - 03:29 PM
got the same idea and dont see a problem with it , better for hiding the vacuum line
Attached File  ɹǝʇsooq2.jpg   66.24K   6 downloads
#5 marko1au
marko1au
  • 207 posts
  • Car:LX sadan
Posted 09 September 2023 - 03:52 PM
UCSLE ................... i cant see what differance it would make .......... to be sure  to be sure
i have a 1976 lx 4 door ....... was originally 6 cylinder .......... im assuming from factory it woul;d have single brake booster..
mark
sorry single diaphram
#6 dattoman
  • 16,485 posts
Posted 09 September 2023 - 04:50 PM
Makes no difference to its operation
Just make sure if its a later one with corresponding pedal the angled end bit points down.
#7 marko1au
marko1au
  • 207 posts
  • Car:LX sadan
Posted 10 September 2023 - 12:54 PM
dattoman ........................ thankyou
#8 marko1au
marko1au
  • 207 posts
  • Car:LX sadan
Posted 10 September 2023 - 01:38 PM
how do you work out the difference between a single or dual diaphram brake booster please ........ can i assume a lx four door 6 cylinder from factory would have a stock single diaphram booster
                  Mark
#9 Uncle Chop Chop
Uncle Chop Chop
    Grumpy Old Man
  • 1,409 posts
  • Name:John
Posted 10 September 2023 - 07:21 PM
The dual one is physically much larger.
#10 dattoman
  • 16,485 posts
Posted 10 September 2023 - 09:33 PM
https://www.gmh-tora...dels-and-types/
#11 marko1au
marko1au
  • 207 posts
  • Car:LX sadan
Posted 16 September 2023 - 05:31 PM
.......... it is the earlier straight one ....... thankyou for pointing that out
                      Mark
#12 marko1au
marko1au
  • 207 posts
  • Car:LX sadan
Posted 17 September 2023 - 09:18 AM
is there a abs booster that suits .......... finding a vh 329 is like looking for hens teeth ......
Mark
#13 dattoman
  • 16,485 posts
Posted 17 September 2023 - 10:56 AM
Mark
A what ?
#14 marko1au
marko1au
  • 207 posts
  • Car:LX sadan
Posted 18 September 2023 - 05:43 PM
A what ?mmmmmmmmmmmmmmm .......... sorry my bad i thought that abs was a manufacturer but they used to be a brake repair place here in SA
#15 dattoman
  • 16,485 posts
Posted 18 September 2023 - 08:17 PM
ABS was a manufacturer in SA .. .usually Hydraulics
About 35+ years ago
#16 claysummers
claysummers
  • 3,570 posts
  • Name:Clay
Posted 18 September 2023 - 11:48 PM
Adelaide brake service I thought it was. Supplied after market replacement master cylinders.
#17 marko1au
marko1au
  • 207 posts
  • Car:LX sadan
Posted 23 September 2023 - 11:48 AM
another question ....... is ve vf commodore vacuum pump running stand alone or inline with engine vacuum .............. im using one as stand alone but would like to know if im pushing my luck using it this way
                  Mark
#18 rexy
rexy
  • 3,677 posts
  • Name:Rexy
  • Car:Kia grand carnival!!!
Posted 23 September 2023 - 01:05 PM
                  Mark
It needs to be in a closed system to make vacuum or it will run continuously and not make any vacuum.
Do not connect to any other piping.
#19 UCSLE
UCSLE
  • 703 posts
  • Name:troy
  • Car:Goggomobil
Posted 24 September 2023 - 12:12 PM
it is a vacuum assist pump and it needs to be connected to engine vacuum by a one way valve
thats what it is made for
you can maybe try running two of them pumps , going to try it on one of my cars but still its a weak pump
Edited by UCSLE, 24 September 2023 - 12:13 PM.
#20 Uncle Chop Chop
Uncle Chop Chop
    Grumpy Old Man
  • 1,409 posts
  • Name:John
Posted 24 September 2023 - 02:10 PM
Hella make one:
https://www.hella.co...umpumpen-10082/
#21 rexy
rexy
  • 3,677 posts
  • Name:Rexy
Posted 25 September 2023 - 12:21 AM
Are you talking about the UP28 Hella pump as fitted to the VE VVT V6?
Attached File  IMG_3029.jpeg   99.39K   6 downloads
This and similar pumps are in every wreckers yard and can be had very cheaply. They are designed to work in a closed system and will pull 20 inches of vacuum with ease. Some come with a useable vacuum control switch like the Volvo one I used in my yellow LJ.
#22 claysummers
claysummers
  • 3,570 posts
  • Name:Clay
Posted 25 September 2023 - 07:59 AM
Might have to fit one of these to my landcruiser. Quoted $800 for a new one 8(
#23 UCSLE
UCSLE
  • 703 posts
  • Name:troy
  • Car:Goggomobil
Posted 25 September 2023 - 12:28 PM
Are you certain it was a closed system in the volvo ?
All the cars i have seen the UP28 in its been a assist pump
It is not about how much vacuum the pump can pull in total but more the length of time it takes
Hella States it as "Typical for support applications" and also has less than half the service life compared to a UP50
You may get away with one if your car has a small booster but the test i did with a LH V8 booster it took longer to reach its vacuum
https://www.hella.co...069076a_AM0.pdf
Attached File  vac motor1.JPG   116.64K   3 downloads
This picture is how a Holden cruze with a UP28 is , stock from factory
Attached File  DSCF1200.JPG   266.54K   4 downloads
Attached File  vac motor2.JPG   25.88K   3 downloads
#24 Uncle Chop Chop
Uncle Chop Chop
    Grumpy Old Man
  • 1,409 posts
  • Name:John
Posted 25 September 2023 - 06:50 PM
I was looking through a Hella  brochure and stumbled across it. I know nothing else, just thought I'd mention it.
#25 marko1au
marko1au
  • 207 posts
  • Car:LX sadan
Posted 07 November 2023 - 02:43 PM
sorry to ask ............... what hg of vacuum is needed to maintain a lx dual diaphragm booster ................ was thinking 17 - 22 ............ but happy to be corrected ...............
