Engine bay harness clips
14 replies to this topic
#1 Proto
Proto
  • 14 posts
  • Name:Frank Wightman
  • Car:LX Hatchback
Posted 19 September 2023 - 06:17 PM
Am chasing the eng bay harness clips which hold the main harness on the LH inner guard
may I ask if anyone knows of where to get some, as can't seem to locate the correct ones in all the normal suppliers.
appreciate any assistance
Probably need to add, this is on an LX hatchback
#2 Proto
Proto
  • 14 posts
  • Car:LX Hatchback
Posted 19 September 2023 - 06:22 PM
I'll get this right shortly!!
The clips are on the RH inner guard.
#3 Shiney005
  • 9,586 posts
  • Car:Toyota Mirai
Posted 20 September 2023 - 09:05 AM
You mean these ones?
Attached File  Screenshot 2023-09-20 070352.png   1.18MB   12 downloads
#4 hanra
  • 10,969 posts
Posted 20 September 2023 - 09:20 AM
These might get you out of trouble for a bit?
https://www.kingswoo...clips-hk/RC0003
#5 yel327
  • 13,633 posts
Posted 20 September 2023 - 09:22 AM
Which A9X is that Laurie? Just wondering why it has a HX intake on it?
#6 Proto
Proto
  • 14 posts
  • Car:LX Hatchback
Posted 20 September 2023 - 04:37 PM
Yes, they are the ones.
Thankyou, the resto country units appear to be correct shape
#7 hanra
  • 10,969 posts
Posted 20 September 2023 - 05:15 PM
In some applications these ones are too short.
#8 Shiney005
  • 9,586 posts
  • Car:Toyota Mirai
Posted 21 September 2023 - 09:53 AM
This is the one on the brand new car that was here in WA. What is the difference?
Attached File  Screenshot 2023-09-21 074904 small.png   1.94MB   8 downloads
Attached File  Screenshot 2023-09-21 075006small.png   1.79MB   6 downloads
#9 yel327
  • 13,633 posts
Posted 21 September 2023 - 01:06 PM
The HX intake is very different to HZ. Have a look at them side by side. Even the broadcast sheet code changed. The dizzy and carby changed too. As far as I was aware only the Sandown display car had a HX engine. The white press test car had a HZ engine.
#10 Shiney005
  • 9,586 posts
  • Car:Toyota Mirai
Posted 22 September 2023 - 08:50 AM
Which one is this?
Attached File  IMG_1378small.jpg   142.5K   8 downloads
#11 yel327
  • 13,633 posts
Posted 22 September 2023 - 09:56 AM
Which one is this?
HX
#12 yel327
  • 13,633 posts
Posted 22 September 2023 - 11:11 AM
Laurie, I meant to say it is a HX one gutted out at the top.
I pinched this image off Gumtree, 3rd from the left is a HZ 5.0L. As far as I am aware, most of the A9X's have the engine code in box 62 for the HZ style engine on their broadcast sheets. The only one I have ever seen with the earlier code on its broadcast sheet is the red hatchback H591125. I might be wrong in that there might be more with the earlier engine.
It was at this transition that the 5.0L engine changed dizzy and carby codes as well.
The HZ manual engine code is ZC. I think HX 5.0L manual is NT. I'm not certain what LX have in those boxes. I'm pretty sure in one of the press test images from 1977 of possibly the white sedan you can see the code painted on the rocker cover.
Attached File  HZ intake.jpg   109.07K   7 downloads
#13 Shiney005
  • 9,586 posts
  • Car:Toyota Mirai
Posted 23 September 2023 - 09:00 AM
A9X engine code is SJ.
#14 Proto
Proto
  • 14 posts
  • Car:LX Hatchback
Posted 23 September 2023 - 09:57 AM
FYI, have had a look at these RC0003, from Resto Country & whilst they look very similar, they are far to small.
#15 yel327
  • 13,633 posts
Posted 23 September 2023 - 10:25 AM
Cool, I'll find out if that is the HX or HZ style engine. I also Googled a few images and lots seem to have the HX style intake which seems odd.
Edited by yel327, 23 September 2023 - 10:34 AM.
