I have a red 308 running an edelbrock 600.
Fuel pressure is 6.2 PSI and would like to get this down to 5 PSI.
What’s the best option for a fuel pressure regulator?
308 Fuel Pressure Regulator
Johno
, Sep 21 2023 02:23 PM
5 replies to this topic
Posted 21 September 2023 - 02:23 PM
Posted 21 September 2023 - 09:05 PM
Why do you want to drop it, 6.2 should be ok.
Posted 22 September 2023 - 08:17 PM
Yeah, i ran a l34 pump kit on a mechanical pump on my 308 with edelbrock carb & manifold, never a drama, carburetor always ran well every time. Fault less i would actually say.
Posted 23 September 2023 - 09:14 AM
The car has been running super rich to the point that it’s putting black soot on my plugs.
I’m just trying to rule out anything that might be causing it to flood.
I’ve just rebuilt the carby so maybe I’ll try running it and see how it is.
I’ve just ordered all the parts for a regulator last night so that’ll happen either way, but might try and get it running without it for now if you think 6.2PSI is low enough.
Posted 24 September 2023 - 12:25 PM
Rubber tipped needle on the float shut-off. Brass floats. helped me solve a problem.
Posted 24 September 2023 - 12:42 PM
It will be viton, not rubber, but a synthetic polymer. Solved a flooding issue I had on the X2 strommies.
