LX Front Stabiliser Bar
5 replies to this topic
#1 Platinum LC
Platinum LC
  • 35 posts
  • Name:Steffan
  • Car:Torana LC, Torana LX
Posted 24 October 2023 - 12:49 PM
Hi Brainstrust, I am fitting a standard front stabiliser bar (sway bar) to my LX. I’m not sure if I am doing it correctly. I have been looking everywhere for photos of what it should look like in situ, but cannot find any of how it should be. In the attached photo mine has been spaced to 7mm below the transmission cover plate. Any help with this would be truly appreciated.Attached File  16621493-F6F1-4494-92B8-28666551BF6E.jpeg   97.57K   7 downloads
#2 hanra
  • 10,975 posts
Posted 24 October 2023 - 12:57 PM
Mine connects to the LCA from the top side. I think you need to remove it and rotate it Right to Left.
Edited by hanra, 24 October 2023 - 12:58 PM.
#3 LXCHEV
LXCHEV
  • 3,611 posts
  • Car:'76 LX - 383 Chev
Posted 24 October 2023 - 01:04 PM
Yeah it needs to be swapped around, so that the forward facing ends contour up and over the lower control arms....
Re-install the link pins above - and it should start looking more like the below...
Here's one I found via a quick google search:
Attached File  Torana front sway bar.JPG   85.1K   5 downloads
#4 ReplicarSLR
ReplicarSLR
  • 518 posts
  • Car:Not anymore unfortunately
Posted 24 October 2023 - 03:24 PM
And the spacers between the bar bushes and the K frame should not be there either unless your extractors are hitting the bar
#5 308 Sunbird
308 Sunbird
  • 973 posts
  • Name:Stuart
Posted 24 October 2023 - 05:01 PM
Yep as said the bar is upside down mate. If you don't have Torana V8 engine mounts (ie: if using HQ etc) the engine will
sit low enough for the extractors to not clear the bar and it will need the spacers.
#6 hanra
  • 10,975 posts
Posted 26 October 2023 - 06:32 PM
I’ve currently my car up on stands.
