A9X Scoop Dimension Check
6 replies to this topic
#1 Stevo75
Stevo75
  • 70 posts
  • Name:Steve
  • Car:LH Torana, HSV R8
Posted 07 November 2023 - 07:50 AM
Hey Guys
Has anyone got an A9X scoop they could ping some dimensions off please?
I've picked up a scoop that I'm re-glassing, but I think it was fitted to a previous bonnet to look seamless. They used a truckload of fixings to hold it down and i suspect may have trimmed the flanges where the fixings go too.
What I'm after if possible is
1. The locations for the correct (factory I guess) screw holes.
2. Which screws are used in which holes (I understand two different types of screws are used to fix the scoops).
3. The width dimension of the flange that the screws fix through. See photo attached where I've measured what I currently have.
And just to check that this scoop is the right size.
4. Overall scoop length. Tip to back down the center.
5. Overall scoop width excluding the flanges.
6. Overall scoop height.
Thanks heaps if anyone can provide this info or even some of it.
Steve
#2 Shiney005
  • 9,578 posts
  • Car:Toyota Mirai
Posted 07 November 2023 - 10:53 AM
Attached File  770701 A9X Bonnet Scoop small.png   1.1MB   11 downloads
#3 Bigfella237
Posted 07 November 2023 - 01:09 PM
So what's that square plate do? I've never seen one of those fitted before.
It looks like it blocks off the hole in the bonnet but I don't see the point... If you don't want a hole then you wouldn't have made the hole?!
#4 hanra
  • 10,968 posts
Posted 07 November 2023 - 01:41 PM
Prob to make the hole legal.
#5 RallyRed
  • 8,144 posts
Posted 07 November 2023 - 02:20 PM
Always thought the square plate was supplied with the new car, in case the owner/ the weather/ the cops,  decided it was necessary.
  i.e. Delivered  in the boot with the new car.   Could be wrong.
#6 Stevo75
Stevo75
  • 70 posts
  • Name:Steve
Posted 07 November 2023 - 04:10 PM
Thanks Shiney
Thats a great diagram. I recon I could scale the hole locations pretty good off that.
Might be pushing it here, but any ideas on the mounting flange width?
I guess I might need someone who has an actual scoop to measure them if possible.
#7 Shiney005
  • 9,578 posts
  • Car:Toyota Mirai
Posted 08 November 2023 - 08:42 AM
Col is on the money.  Drawn back in July '77.
Attached File  Bonnet scoop hole cover 14 July 1977.JPG   133.37K   9 downloads
The hard part would be finding an original one not on a car if you wanted to be accurate.  I doubt that any of the aftermarket ones would be the same.
Edited by Shiney005, 08 November 2023 - 08:43 AM.
