Hi Guys,
Where is the best location to drill a 50-diameter hole in the firewall so the LS harness is more concealed?
Cheers..
Joe
Posted 29 November 2023 - 08:52 PM
Hi Guys,
Cheers..
Joe
Posted 30 November 2023 - 03:47 AM
I have it under the blower housing, not exactly concealed but I think fairly neat. If you go below the top of the chassis rails it becomes too low inside the car.
If you want it hidden then there is room to exit the cabin under the guard, but you still need to find ways to get the required wiring into the engine bay from there.
Posted 30 November 2023 - 08:11 AM
Thanks mate. Appreciate your reply
Posted 30 November 2023 - 10:01 AM
You can go a much smaller hole with a bit of extra work.
You could easily go down to a 25mm hole.
Just label the wires and depin the connectors.
I mounted my PCU externally so went for a slightly different setup as it would be exposed.
I ended up with a 32mm hole and compression gland to keep the moisture out.
Rob
Posted 30 November 2023 - 10:19 AM
Keep in mind that if you go with the inner guard option you'll need to make sure it's extremely waterproof as spray will be flung off the tyre with reasonable force when driving in the rain (not to mention dirt, mud, rocks, roadkill guts, pieces of shredded tyre, and so on)!
Posted 30 November 2023 - 12:18 PM
Posted 30 November 2023 - 03:24 PM
