LJ Standard disc Brake Improvements
LJ Brakes LC Disc
67 replies to this topic
#51 S pack
  • 15,725 posts
Posted 12 December 2023 - 06:26 AM
went for these
https://www.vmaxbrak...-xu-1-1972-1973
with theses spacers
https://www.powerbra...size1/offset/0?
Hopefully will get time to fit over the christmas break & will report back.
Cheers for all the help.
Bruce, just note that you do not use the two kidney shaped caliper mounting spacers on LC/LJ Torana. They are HK,T,G only.
#52 salamiman
salamiman
  • 130 posts
  • Name:Bruce
  • Car:LJ 2 door tribute
Posted 12 December 2023 - 11:55 AM
Thanks Dave
#53 grumpy xu1
grumpy xu1
  • 2,812 posts
  • Name:Gary
  • Car:lj xu1
Posted 12 December 2023 - 07:25 PM
Thanks Dave
Good work Dave, i was going to advise the same. Bottom gold 1's only.
#54 salamiman
salamiman
  • 130 posts
  • Name:Bruce
Posted 23 December 2023 - 05:30 PM
Attached File  PXL_20231223_050101278.jpg   70.94K   1 downloads
Got one disc done today.
Merry Christmas to all.
#55 claysummers
claysummers
  • 3,636 posts
  • Name:Clay
Posted 23 December 2023 - 07:46 PM
Looking good. Vmax do slotted/dimpled rotors for HR also I see.
#56 grumpy xu1
grumpy xu1
  • 2,812 posts
  • Name:Gary
  • Car:lj xu1
Posted 26 December 2023 - 08:08 PM
Let us know your thoughts on the new rotors ect mate, once she's up and running.
#57 salamiman
salamiman
  • 130 posts
  • Name:Bruce
Posted 03 January 2024 - 08:30 PM
will do
rotors are in,
but my speco fuel reg sprung a leak just b4 testng, bloody lucky, its on the exhaust side & could have been a disaster, boom!
Ordered a new holley one, no fittings inc, so waiting on some 3/8 npt barbs ect, will now fit on the drivers side.
Report back soon!
#58 claysummers
claysummers
  • 3,636 posts
  • Name:Clay
Posted 03 January 2024 - 09:47 PM
Bugger. I’ve got a speco one and heard about them springing a leak. Malpassi are apparently good.
#59 salamiman
salamiman
  • 130 posts
  • Name:Bruce
Posted 04 January 2024 - 01:17 PM
Did see on the back of the speco unit 7lb max, I was feeding it with a SBC manual pump, I assume it supplied over 7lb.
speco unit was 2 yrs old
#60 claysummers
claysummers
  • 3,636 posts
  • Name:Clay
Posted 04 January 2024 - 04:40 PM
Thanks for that qualification. I'm running AC glass bowl type, though I may have changed the base over to the later blue black version. Anyway they are rated under 6psi, so good to know.
#61 salamiman
salamiman
  • 130 posts
  • Name:Bruce
Posted 06 January 2024 - 08:14 AM
I originally ran the SUs back in the day with a STD red 173(2650) Manual fuel pump with no Reg & had no overflow issues.
Went with the SBC pump this time so i had no fuel supply issues(overflowed so need a Reg), sometimes bigger is not always better.
I never tested the amount of fuel supplied with the orig unit, it may have been fine?
#62 claysummers
claysummers
  • 3,636 posts
  • Name:Clay
Posted 06 January 2024 - 12:12 PM
My mate was running his 300 flywheel hp 202 webers off standard pump no reg, but he put roller lifters and had to go to electric pump.
#63 salamiman
salamiman
  • 130 posts
  • Name:Bruce
Posted 06 January 2024 - 08:18 PM
There you go, I would have been fine, I wouldnt be anywhere near that, if i have any probs with this holley reg, ill revive the old pump, & one less thing to worry about.
#64 salamiman
salamiman
  • 130 posts
  • Name:Bruce
Posted 04 April 2024 - 07:47 PM
Hi All,
Back up & running again.
Brake report.
Booster tested as per S pack Dave, all good, but note this booster is now on 52 yrs old??
Cam is crow 35803, from mem 108 lobe separation, 248 @ .05.
Front Brakes wont lock up, but pull up pretty quick, passed pink slip brake test easily.
New master, reco calipers, new brake rubber lines, new rear slaves & adjusted, all lines bled, no rusty brake fluid???
Wondering if the diaphragm has hardenened or became too stiff, am i producing enough vac with said cam?
Any thoughts appeciated.
Edited by salamiman, 04 April 2024 - 07:49 PM.
#65 dattoman
  • 16,487 posts
Posted 04 April 2024 - 09:05 PM
How much vac do you have ?
Tested in inches of mercury
#66 salamiman
salamiman
  • 130 posts
  • Name:Bruce
Posted 05 April 2024 - 01:21 PM
Was wondering that myself, dont have a vac gauge, will get a hold of one, how much am I chasing for decent braking with a std booster?
#67 dattoman
  • 16,487 posts
Posted 08 April 2024 - 09:56 PM
18-20"
#68 salamiman
salamiman
  • 130 posts
  • Name:Bruce
Posted 12 April 2024 - 09:15 PM
18-20"
Thanks dattoman.
Appreciated
Also tagged with one or more of these keywords: LJ, Brakes, LC, Disc
