72 LJ tidy up
28 replies to this topic
#1 Grumpy72LJ
Grumpy72LJ
  • 27 posts
  • Name:Darren
  • Car:1972 LJ
Posted 17 January 2024 - 08:16 PM
Hi,
Not a build thread by any means, more sharing what I have seen. My first Torana at 17 was a 71 LC 4 door with opel slant 4. A wreck to look at but reliable. Next was a red hot and bogged up Bathurst green 72 LJ. 186s mild cam tripper 1.75” SUs, all the good bits. I had to let go of that car around 28 years ago and regretted it. Next was a UC sunbird with star fire 4. Don’t judge me on that one. Fast forward 28 years and a nice 72 Lj 4 door has been guided into my hands. Brought it from best mates son. I am 5th owner. 3rd owner built the engine and it has about 15K miles on it and is a stonker. I pity the M20 sitting behind it. I have all doco for the car including the bill of sale for $2458 as a 3 speed column shift in the day. I will post some pics of mods and hoping you enjoy them.
#2 Grumpy72LJ
Grumpy72LJ
  • 27 posts
  • Name:Darren
  • Car:1972 LJ
Posted 17 January 2024 - 08:27 PM
The car
#3 Grumpy72LJ
Grumpy72LJ
  • 27 posts
  • Name:Darren
  • Car:1972 LJ
Posted 17 January 2024 - 08:32 PM
First big and important job was replacement of the rear upper and lower trailing arms. What an improvement in ride and handling.
The old ones were shot by comparison
#4 Grumpy72LJ
Grumpy72LJ
  • 27 posts
  • Name:Darren
  • Car:1972 LJ
Posted 17 January 2024 - 08:35 PM
Oh then there’s the Bev Brock signed glovebox obtained by previous owner at a car meet.
#5 Grumpy72LJ
Grumpy72LJ
  • 27 posts
  • Name:Darren
  • Car:1972 LJ
Posted 17 January 2024 - 08:37 PM
Then moved on to do tappet cover and side plate gaskets which cured the Holden 6 moisture
#6 Grumpy72LJ
Grumpy72LJ
  • 27 posts
  • Name:Darren
  • Car:1972 LJ
Posted 17 January 2024 - 08:40 PM
Next was giving those lovely sprinter rims some paint with those gorgeous Holden long tail centre caps
#7 Grumpy72LJ
Grumpy72LJ
  • 27 posts
  • Name:Darren
  • Car:1972 LJ
Posted 17 January 2024 - 08:43 PM
Previous owner said that it sometimes get stuck in reverse… I though WT? Turns out the reverse linkage on the M20 was installed the wrong way around and was binding on the side of the gearbox.
#8 Grumpy72LJ
Grumpy72LJ
  • 27 posts
  • Name:Darren
  • Car:1972 LJ
Posted 17 January 2024 - 08:45 PM
Oh and here is the imperial bolts I somehow carried around with me my whole life from when I disassembled a blown 161 when I was about 12
#9 Grumpy72LJ
Grumpy72LJ
  • 27 posts
  • Name:Darren
  • Car:1972 LJ
Posted 17 January 2024 - 08:48 PM
Then I moved on to cleaning the under carriage. As usual lots of grease. But because the car grew up in orange NSW lots of orange dust and VERY little rust
#10 Grumpy72LJ
Grumpy72LJ
  • 27 posts
  • Name:Darren
  • Car:1972 LJ
Posted 17 January 2024 - 08:51 PM
Exhaust was a 2” into xu1 style muffler. It was a shocker. Toronto exhaust did an amazing job on a 2.25” into baffled muffler. Sounds wonderful.
#11 Grumpy72LJ
Grumpy72LJ
  • 27 posts
  • Name:Darren
  • Car:1972 LJ
Posted 17 January 2024 - 08:53 PM
Then moved on to uni joints and gave them a freshen up
#12 Grumpy72LJ
Grumpy72LJ
  • 27 posts
  • Name:Darren
  • Car:1972 LJ
Posted 17 January 2024 - 08:56 PM
Then into the dirty and frustrating business of rear shoe and cylinder replacement. Note the passenger side rear cylinder was completely frozen. Not sure for how long…
#13 Grumpy72LJ
Grumpy72LJ
  • 27 posts
  • Name:Darren
  • Car:1972 LJ
Posted 17 January 2024 - 08:59 PM
As it started life as a 3 tree, it still had the collar. I needed to make it look like A 4 floor so delved into this mess.
Had no idea what I was doing but turned out ok
#14 Grumpy72LJ
Grumpy72LJ
  • 27 posts
  • Name:Darren
  • Car:1972 LJ
Posted 17 January 2024 - 09:02 PM
Next the steering rack came out. It wasn’t too bad but want to do it once and once only. It was a fun job getting alignment right. Just don’t move anything while you do it.
#15 Grumpy72LJ
Grumpy72LJ
  • 27 posts
  • Name:Darren
  • Car:1972 LJ
Posted 17 January 2024 - 09:05 PM
So the old 2 core radiator, while up to the job worried me. So fitted an alloy 3 core with twin 9” thermos. It’s good so far let’s see how long it lasts. I also put in a thermos bypass so if the sender fails I can manually switch on.
#16 Grumpy72LJ
Grumpy72LJ
  • 27 posts
  • Name:Darren
  • Car:1972 LJ
Posted 17 January 2024 - 09:08 PM
Here is the VBcommodore thermo housing. Fitted with a British thread reducer to accommodate the NPT? Thread sender
#17 Grumpy72LJ
Grumpy72LJ
  • 27 posts
  • Name:Darren
  • Car:1972 LJ
Posted 17 January 2024 - 09:12 PM
Then I moved to rust prevention. These things rust away while you look at them. Since I’m in phase 1 bodywork, gearbox and diff come later. So this was to prevent rust advancement temporarily.
After my big job
#18 Grumpy72LJ
Grumpy72LJ
  • 27 posts
  • Name:Darren
  • Car:1972 LJ
Posted 17 January 2024 - 09:16 PM
More recently I moved on to LED light and relay replacements that have had stunning results. Since she started life as a column shift 3 speed, she never had a 4 speed reverse light switch, so that is my next job. God knows how she got through rego the last 5 years…
#19 Grumpy72LJ
Grumpy72LJ
  • 27 posts
  • Name:Darren
  • Car:1972 LJ
Posted 17 January 2024 - 09:20 PM
#20 Grumpy72LJ
Grumpy72LJ
  • 27 posts
  • Name:Darren
  • Car:1972 LJ
Posted 17 January 2024 - 09:23 PM
Oh yes the motor. Pretty cranky. What I know is: 179 forged crank, 186P black, pistons and rods unknown, ported head with Crow stg2 cam, Stromberg Ww carb, enormous extractors, electronic ignition. It hauls.
#21 RallyRed
  • 8,146 posts
Posted 17 January 2024 - 09:51 PM
Great work
#22 Grumpy72LJ
Grumpy72LJ
  • 27 posts
  • Name:Darren
  • Car:1972 LJ
I am also after a tremec / Borg Warner T5 replacement gearbox new or used fresh. To suit an LJ. Please let me know if you have something.
#23 4dabush
4dabush
  • 226 posts
  • Name:Adam
  • Car:73 LJ S
Posted 17 January 2024 - 10:32 PM
Talk to Mal Wood Automotive. Might be a bit exy to start with but probably cheaper in the long run…I probably ended up 50% more trying to be cheap about the conversion.  He is very busy and can be slow to get back to you, but he will, I’ve had calls back at 8 at night and middle of Sunday.
#24 Ice
  • 15,200 posts
Posted 17 January 2024 - 10:39 PM
Well someone has been busy
great work Darren
#25 Grumpy72LJ
Grumpy72LJ
  • 27 posts
  • Name:Darren
  • Car:1972 LJ
Posted 18 January 2024 - 07:47 AM
Thanks.
