ARP torque specs
Posted 13 February 2024 - 11:02 AM
Would anyone know offhand how tight to torque these up?
Need the starfire rod bolt and main stud numbers
Oh, it’s a blue 202 in case that helps
Posted 13 February 2024 - 10:08 PM
Posted 14 February 2024 - 09:19 AM
It states:
“Important note:
Tighten bolts to Holden specifications”
That’s 35ft/lbs, and the arp link says 55 for kit 134-6003 and 134-6023
For chev 305 - 350
Checking the ad again I notice the Holden starfire kit number is
205-6001-ho6.
Those may be the wrong kit.
Also, the machinists had considerately etched the words
“Torque to 70 ft/lbs on arp main studs” with a Dremel on
the block oil pan surface, so that cleared that one up.
I do appreciate your help Warren, I just want to put this out there to
save anyone a potential heartache if I happen to be right here.
Tell me if I’ve got it wrong though, or the heartache will be mine
Posted 14 February 2024 - 09:51 PM
I torque mine as per the ARP leaflet, they've been in my engine for 24 years, my second engine for 20 years & all other Holden 6's that I've built.
Posted 14 February 2024 - 09:55 PM
Posted 15 February 2024 - 05:23 AM
I torque them, I can't measure the stretch. If the rods were fitted with ARP bolts, torqued, then honed, that is the torque too be used.
Posted 15 February 2024 - 09:46 AM
Do you do them up to 55 or do you measure the bolt stretch?
Bolt stretch seems to be a thing for some OEM bolts that are single use only.
Aftermarket stuff I have come across have been reusable and are torque value.
Rob
