Door cavity holes - why?
12 replies to this topic
#1 SmacT
SmacT
  • 1,002 posts
  • Name:Sam
  • Car:LX 4dr 383, TKX, BW
Posted 20 February 2024 - 01:47 PM
Hi legends,
Can anyone tell me what these holes are for? There are three in each door cavity. They aren't factory I am pretty sure, and figured someone wanted to cavity wax their sills. I didn't spot them before paint so I guess plugging them with suitable grommets and sikaflex is the way to go. Or are they factory-spec speed holes for late '77 Toranas and I should just add plutonium? Hoping for the latter...
Attached File  IMG_3390.jpg   195.68K   9 downloads
#2 arrimar
arrimar
  • 3,134 posts
Posted 20 February 2024 - 01:50 PM
Why there and not under the kick plate?
#3 claysummers
claysummers
  • 3,664 posts
  • Name:Clay
Posted 20 February 2024 - 03:55 PM
Probably done when no one cared. The rustproofing game was a rodeo in the late 70s when it boomed..
#4 yel327
  • 13,717 posts
Posted 20 February 2024 - 04:17 PM
Rustproofing my guess. They put plastic plugs in them.
#5 RallyRed
  • 8,179 posts
Posted 20 February 2024 - 05:21 PM
Yeah, they must have been in a hurry and couldn't be bothered lifting the sill cover plates.
#6 SmacT
SmacT
  • 1,002 posts
  • Name:Sam
Posted 20 February 2024 - 09:14 PM
Yeah bugger. Shame I didn't realise before I painted it. Oh well - at least I know it worked, bugger all rust in this car. Ha ha. Thanks fellas.
#7 71xu1
71xu1
    Dave
  • 1,275 posts
  • Car:LC GTR XU1
Posted 20 February 2024 - 11:57 PM
I worked at a dealership in the 80s 90s as a smash repairer, we had a guy that worked at the rear of the shop doing rustproofing (end rust) all day everyday. He was always under the pump no time to take scuff plates off etc. most of the time when we got the cars back for warranty rustwork it was around where the holes were drilled. If you get stuck for plugs I may have some.
#8 meanmachine72
meanmachine72
  • 2,043 posts
  • Name:Jono
Posted 21 February 2024 - 07:30 AM
i worked at Hornsby Datsun and they had a fella called Gargoyle doing  End Rust all day 6 days a week.
always   covered. in the sticky crap.. as what dave says above when the warranty claims started to roll in most rust claims
where in and around the dill holes to spray the golden goo in
#9 Bigfella237
Posted 21 February 2024 - 01:11 PM
I used to do rustproofing in a dealership myself but we used WaxOyl (that stuff was awesome, and a hell of a lot less messy than EndRust), but I never drilled a hole in a single car! (Although I was allowed the time to remove the odd trim panel instead.)
WaxOyl had a selection of wands that you could get into the drain holes that are already in most panels, plus that stuff kinda misted in through all the cavities anyway. You could squirt it into the front of a sill panel and see it coming out the drain holes at the rear.
I don't think we ever had a single warranty claim from the rustproofing.
When we first started doing it, I did a test by applying it to half of a piece of bare mild steel, I probably still have that bit of steel somewhere (although I don't know where), but even a decade later the half that got rustproofed still looked brand spanking!
#10 claysummers
claysummers
  • 3,664 posts
  • Name:Clay
Posted 21 February 2024 - 08:20 PM
It would b e interesting to try and find a current day equivalent. Sounds pretty good.
#11 yel327
  • 13,717 posts
Posted 22 February 2024 - 05:03 AM
Fergusons stuff looks good.
#12 claysummers
claysummers
  • 3,664 posts
  • Name:Clay
Posted 22 February 2024 - 06:56 AM
Yes
#13 arrimar
arrimar
  • 3,134 posts
Posted 22 February 2024 - 05:12 PM
3M Cavity Wax spray kit with the super long nozzles is the go.
