Does anyone have a parts diagram for the LX Torana PBR alloy calipers?
Posted 10 March 2024 - 05:03 PM
Posted 10 March 2024 - 06:27 PM
They should be the same as the HZ PBR Caliper, other than the cast iron bracket being smaller on the LX to accommodate the thinner disk - and having Torana cast into the bracket rather than Holden
Posted 11 March 2024 - 05:57 AM
That picture is actually of a Torana body as it has the hose connection drilled and tapped in the top.
Posted 11 March 2024 - 01:17 PM
If you buy a kit to rebuild them you will have parts left over .
There is 2 different seals for the sleeve , the kit usually comes with both
Posted 11 March 2024 - 02:26 PM
That's because the Torana uses a different sleeve for one side. The sleeve closest to the tie rod has a recessed Allen headed bolt whereas the Holden caliper has two traditional hex headed bolts.
Posted 11 March 2024 - 04:09 PM
narr i know what you are talking about the recessed bolt , thats not it .
They change from a boot and a o-ring on the sleeves (like in the diagram ) , too dual boots on each sleeve
Dont know what year it got changed but thinking its about 78
Have some different ones here if you what pictures ?
