NOT another XU1 battery thread
4 replies to this topic
#1 rodomo
  • 18,037 posts
Posted 22 March 2024 - 09:04 PM
There have been quite a few threads about replacement XU-1 batteries over the years.
https://www.google.c...sclient=gws-wiz
This thread is about a suitable battery, not for the rivet counters, that will fit under the bonnet (not in the boot) if you have non standard triples on a longer runner manifold. Maybe not triple Webbers though?
The RoDoMo research and development team has spent countless hours scouring old catalogues and doing the legwork around spare parts stores with a measuring tape in the hope of finding one.
We've settled on a Supercharge battery, MF44.
It was on special Wednesday (a still maybe???) for $160 at Autobahn.
It measures 175mm H, 175mm W and 210mm L.
It is 510cca which is way more than a standard Torana battery AND comes with a 50 month warranty. (I hope this warranty doesn't expire before my car is on the road?)
It will need a fabricated bracket as it clamps on a ridge around the bottom of the battery but this eliminates the standard clamp bracket which adds to the height.
It will give more than 20mm clearance to the bonnet at the negative post and shitloads to the positive post.
I'll add pics as I make the bracket.
#2 Shiney005
  • 9,578 posts
  • Car:Toyota Mirai
Posted 24 March 2024 - 11:29 AM
The Yellow Sticker MF44 was only fitted to '72 XU1's between March and May.  You need the Green Sticker.  :)
#3 rodomo
  • 18,037 posts
Posted 24 March 2024 - 09:05 PM
:fool:
#4 IanC
IanC
  • 605 posts
  • Name:Ian
  • Car:LJ XU-1
Posted 25 March 2024 - 06:38 AM
I have been looking at this one. The colours not awesome. But should have plenty of power.https://www.centuryb.../products/67-mf
#5 jpxu1
jpxu1
  • 571 posts
Posted 25 March 2024 - 10:27 PM
Ian, you can get the same battery in the sister brand Yuasa in a much more sensible black case :-)
https://www.batteryw...RA-Auto-Battery
