Lower engine
6 replies to this topic
#1 Johno
Johno
  • 209 posts
  • Name:John
  • Car:LX Torana
Posted 31 March 2024 - 11:52 PM
I have a 308 in an LX.
Bracket for clutch fluid resovior is welded to the firewall. My rocker covers sit about a millimetre under it.
As I’m swapping engine and new engine requires taller rocker covers due to roller rockers, is there anything I can do to get the engine to sit lower like thinner engine mounts or something?
Or should I grind the bracket off and relocate?
The clutch fluid bracket seems to be in the same spot as factory and I’m wondering if this clearance issue is a common problem.
#2 RoyalPlum76SS
RoyalPlum76SS
  • 236 posts
  • Name:John
  • Car:SS Hatch
Posted 01 April 2024 - 12:00 AM
You could try HQ engine mounts, they will drop the engine down around 10mm.
#3 hanra
  • 10,920 posts
Posted 01 April 2024 - 08:02 AM
Use a standard clutch setup?
#4 yel327
  • 13,575 posts
Posted 01 April 2024 - 09:12 AM
As above try HQ-WB engine mount adapters. You might end up with exhaust clearance issues but if you aren't using extractors should be OK. There is no factory hydraulic clutch setup.
#5 arrimar
arrimar
  • 3,134 posts
Posted 01 April 2024 - 11:35 AM
Could switch to an underdash hydraulic system.
#6 Johno
Johno
  • 209 posts
  • Name:John
  • Car:LX Torana
Posted 01 April 2024 - 08:43 PM
Thanks all. Ok so maybe this is a custom thing that was put on when the supra 5 speed was put in.
The car has extractors so that might be an issue.
I don’t understand why someone would weld it to the firewall.
#7 rexy
rexy
  • 3,666 posts
  • Name:Rexy
  • Car:Kia grand carnival!!!
Posted 02 April 2024 - 11:13 AM
Just clearance the rocker cover as we always did for this setup
