Car Leans to drivers side
12 replies to this topic
#1 Johno
Johno
  • 217 posts
  • Name:John
  • Car:LX Torana
Posted 01 April 2024 - 09:04 PM
I have an LX four door that leans to the drivers side.
I know it’s got a crook ball joint but not sure if any other suspension components might be causing this.
Im concerned it might be a twisted or bent chassis. If it is, is this fixable?
#2 Johno
Johno
  • 217 posts
  • Name:John
  • Car:LX Torana
Posted 01 April 2024 - 09:12 PM
I reckon the lean is about an inch.
#3 LCK186
LCK186
  • 391 posts
  • Car:71 CK
Posted 01 April 2024 - 09:28 PM
Hi it sounds like a saggy spring, it can also be the rear spring, which can cause it to lean, as for chassis anything is repairable, i would pull out and measure the springs height, or take them to a spring retentioner, its not expensive around 50 to 100 dollars i hope this helps you
#4 Johno
Johno
  • 217 posts
  • Name:John
  • Car:LX Torana
Posted 01 April 2024 - 09:30 PM
Thankyou mate. I always tend to suspect worst case scenario haha but will follow your advice
#5 rexy
rexy
  • 3,740 posts
  • Name:Rexy
  • Car:Kia grand carnival!!!
Posted 02 April 2024 - 11:15 AM
45 years of a fat driver?
#6 RallyRed
  • 8,150 posts
Posted 02 April 2024 - 11:51 AM
Swap the springs left to right...see if the sag follows?
#7 Johno
Johno
  • 217 posts
  • Name:John
  • Car:LX Torana
Posted 02 April 2024 - 12:15 PM
Rexy this was also a suspicion hahah.
#8 kimbo
kimbo
  • 110 posts
  • Name:Kim
  • Car:LX Torana Hatch (looking 4 1)
Posted 02 April 2024 - 04:37 PM
Https://www.weightwatchers.com au
They will fix it for ya
Sent from my SM-G988B using Tapatalk
#9 Shiney005
  • 9,603 posts
  • Car:Toyota Mirai
Posted 06 April 2024 - 09:38 AM
Or it could be worst case scenario. Any big hit in a front corner of a Torana can (and usually does) amount to a bent chassis rail.  Still repairable, but a lot more work.  Pop the bonnet so it is still on the second catch and see if there is a difference between the gap between it and the nose cone from one side to the other.
#10 Johno
Johno
  • 217 posts
  • Name:John
  • Car:LX Torana
Posted 16 June 2024 - 07:31 PM
Posted a new thread about this but will just post it in here instead.
I noticed when jacking the rear end up at the middle of the diff, there was a 1.5 inch gap on the passenger side compared to the drivers side when I went to put car stands under it.
Would this mean anything that the difference is at the axles?
To answer your question Shiney, the front of the bonnet is square when I compare both sides.
#11 claysummers
claysummers
  • 3,636 posts
  • Name:Clay
Posted 16 June 2024 - 07:42 PM
Measure hub centre to top of guard for each wheel. I bet the front driver is smaller thn passenger. Typical with age.
#12 Shiney005
  • 9,603 posts
  • Car:Toyota Mirai
Posted 17 June 2024 - 11:05 AM
Time to swap the springs me thinks.
#13 Heath
  • 18,393 posts
Posted 18 June 2024 - 10:04 AM
Jack up one end of the car at a time and see which end of the car is dominated by the irregularity.
(it is probably the front, as the wheel rate at the front is higher)
Remove the front shocks and look up through the shock hole to make sure that the front springs are seated correctly at the top. They can also be located weirdly in the lower perches. People often stuff this up and it would relate in about a 1" difference I would think.
If you can get your hands on corner-weighting scales, you can really interrogate the issue and chase it down to nothing by cutting front springs and spacing or re-setting rear springs. Post below on me doing mine:
https://www.gmh-tora...atch/?p=1092086
