LC rear indicator screws
LC GTR indicator indicator screws
34 replies to this topic
#1 dacastle
dacastle
  • 107 posts
  • Car:LC gtr
Posted 06 April 2024 - 04:05 PM
Does anyone have any pics of metal threads used to hold on / retain the rear indicators on the rear quarter panel
#2 stealthxu1
stealthxu1
  • 350 posts
  • Name:Stealth
  • Car:lc 2 door project
Posted 06 April 2024 - 07:23 PM
I did see a good example on ebay don't have a link sorry
#3 Flaming Skull 57
Flaming Skull 57
  • 130 posts
  • Name:John Harris
  • Car:LC Torana "Gilberts Stinger"
Posted 07 April 2024 - 09:17 AM
Off Topic. I have noticed some LC S models, and some LC GTR models (as above) have the 2 chrome lines on the lens, and some don't. I have Looked at heaps of photos and they all differ.
I thought the chrome lines were for GTR's but many GTR's don't have the chrome lines. Also, some have the background painted black and some silver. Again, can't find a common pattern. They all differ and have different combinations.
John
#4 Flaming Skull 57
Flaming Skull 57
  • 130 posts
  • Name:John Harris
Posted 07 April 2024 - 10:56 AM
Also Front indicator lens are Clear or Amber. Did certain colors come out on specific LC models or is it personal preference?
#5 RallyRed
  • 8,150 posts
Posted 07 April 2024 - 12:45 PM
I understand all LC GTRs had the lines.
Clear >> Amber fronts were due to an ARD change. i e before the change they were supplied clear/ white and after, Orange.
#6 Flaming Skull 57
Flaming Skull 57
  • 130 posts
  • Name:John Harris
Posted 07 April 2024 - 12:48 PM
Thanks Col. Do you know when the date the ADR change happened? My LC is 8/1971 with clear lenses.
#7 RallyRed
  • 8,150 posts
Posted 07 April 2024 - 12:49 PM
Best pics I can find of the side repeaters...
#8 Flaming Skull 57
Flaming Skull 57
  • 130 posts
  • Name:John Harris
Posted 07 April 2024 - 01:57 PM
Just found this post
https://www.google.c...h-&opi=89978449
#9 dacastle
dacastle
  • 107 posts
  • Car:LC gtr
Posted 07 April 2024 - 03:09 PM
Thanks Col
they look like self tapping screws rather than metal threads - is that correct
#10 RallyRed
  • 8,150 posts
Posted 07 April 2024 - 03:17 PM
Don't have the LC any longer mate.
Thinking they were the typical rounded head, phillip's head self tapper, but no point on the threaded end, more of a snub nose??
#11 RallyRed
  • 8,150 posts
Posted 07 April 2024 - 03:21 PM
Something like this, but without the washer?. Someone with a LC in the shed may chime in...
#12 yel327
  • 13,643 posts
Posted 07 April 2024 - 05:25 PM
Screws could be SP1801. If you can tell me where the quarter lamps are in the parts catalogue I can look up the screw specs in the HQ book.
#13 Indy Orange
Indy Orange
  • 2,945 posts
  • Name:Paul
Posted 07 April 2024 - 07:06 PM
https://www.ebay.com...ASABEgKy5fD_BwE
#14 RallyRed
  • 8,150 posts
Posted 07 April 2024 - 07:36 PM
Nice work, so the do go to a point..but flattened a bit on the end?
#15 Dr Terry
Dr Terry
  • 3,325 posts
Posted 08 April 2024 - 07:46 AM
John
With over 50+ years of ownership most Toranas have had things changed, due to either smash repairs or owner modification, so most of the cars you see today have been altered.
AFAIK when they left the factory gate, there were only 2 versions of LC tail-light. GTR (Incl. XU1) & SL got black infilled surrounds & chrome lines across the lens face while Torana S & base 4-cyl models got silver surrounds & plain lenses.
The screws for the rear side blinker repeaters are self-tappers.
Dr Terry
#16 Flaming Skull 57
Flaming Skull 57
  • 130 posts
  • Name:John Harris
Posted 08 April 2024 - 09:04 AM
Thanks Dr Terry
#17 yel327
  • 13,643 posts
Posted 08 April 2024 - 09:07 AM
As per my post above, if someone want to look through the LC Parts catalogue and tell me where the quarter lamps are as in what GROUP, I'll get you the screw specs. Then you can buy them for 5c each from a bolt/nut/screw shop.
#18 Dr Terry
Dr Terry
  • 3,325 posts
Posted 08 April 2024 - 09:47 AM
Hi Byron.
Yes the Group no. is 2.589 & the P/No. for the screw is SP1801
Dr Terry
#19 yel327
  • 13,643 posts
Posted 08 April 2024 - 11:14 AM
That's an easy one. Will type up its specs later this arvo.
#20 Dr Terry
Dr Terry
  • 3,325 posts
Posted 08 April 2024 - 03:44 PM
The ADR for orange front blinkers wasn't officially introduced until 1/73, but they were in production in 10-11/72, which is mid-LJ, so all LC got white/clear front blinkers.
Dr Terry
#21 yel327
  • 13,643 posts
Posted 08 April 2024 - 06:02 PM
OK, SP1801 is:
Screw - Sheet Metal Pan Head. Imperial No.10 - 16tpi x 1.125" cr. rec (I think cr. rec. means cross recessed which is the pan philips head).
Seems awful long to me though, as we sure this is the screw?
#22 S pack
  • 15,726 posts
Posted 08 April 2024 - 09:17 PM
SP1801 are the screws for the FRONT indicator lens to body.
#23 S pack
  • 15,726 posts
Posted 08 April 2024 - 09:21 PM
Lamp Assy - Rear side (amber lens) is listed in Group 2.679 in the LC Parts catalogue but no attaching screw part numbers are listed.
#24 yel327
  • 13,643 posts
Posted 09 April 2024 - 06:44 AM
Will require a bit more work. Would simply be a matter of getting an original and going to a screw shop and seeing if they were no.8 or no.10 and buying in the right thread and right length.
HQ doesn't list a screw for the same spot but HJ does - 9414724, Pan Head, No.10 =- 16 x 3/4. There is the answer I think.
#25 S pack
  • 15,726 posts
Posted 09 April 2024 - 07:12 AM
I suspect you are correct. Looking at some pics of those LC side indicators for sale on ebay, they look like they need a 10g x 3/4" (or thereabouts) Philips pan head self tapping screw.
Also tagged with one or more of these keywords: LC GTR, indicator, indicator screws
