Speedo calibration
2 replies to this topic
#1 Rana101
Rana101
  • 48 posts
  • Name:Derek
  • Car:Lh
Posted 07 April 2024 - 12:58 PM
Good afternoon all
   Need to get speedo calibration done on my LH for certification here in NZ
 have 186 ,with W50 5 speed ,3.08 diff  , 205/70 R14 tyres
have just done gps check and at 62 kmh car reads 50 kmh
 at 100kmh car reads around 82.
my question is can I get different size speedo gears for W50 ?
or any other suggestions would be appreciated need to get it 2% accurate
thank you
Derek
#2 yel327
  • 13,643 posts
Posted 07 April 2024 - 05:03 PM
You should be able to buy the gears for them. You will have to work out from the teeth on the drive and driven gears you have now and then work out what you need, then go looking at sites for Toyotas to find what you need.
For example it looks like you need to drive the speedo cable 25% faster. If your current gears are say 7 teeth drive and 24 teeth driven you need to drop the driven teeth count by 25% so will need to drop to about 18 teeth (which may not be available). You may have to do it by swapping to say 8 teeth on the drive gear which will be around 21 teeth on the driven gear. However these gears may not be available. Here is a place in Australia that sells 19 and 20 teeth driven gears but read the notes:
https://www.sq-engin...e-speedo-drive/
I have a couple of these boxes in pieces that I'd give to you if you were local, plus another complete box. Will probably have the same gears as yours though.
You can order these things too, possibly cheaper elsewhere to get into NZ:
https://www.kinselas...edo-calibration
The other option is buy a GPS cable drive and do it external to the gearbox, again not cheap but you may be able to buy from JEGS or SUMMIT in the USA and ship to NZ:
https://malexmotorsp...eiCtnVgeTbtnWLg
#3 Rana101
Rana101
  • 48 posts
  • Name:Derek
  • Car:Lh
Posted 07 April 2024 - 06:12 PM
Thank you
will get apart and go from there appreciate the reply
