OS Formula hotwires don't fit Hoppers
16 replies to this topic
#1 kimbo
kimbo
  • 110 posts
  • Name:Kim
  • Car:LX Torana Hatch (looking 4 1)
Posted 26 April 2024 - 01:32 AM
So these wheels have a rim (lip) for clipping the center cap to. The Hoppers hubs are the proper diameter but deeper. So the locator component of the wheel fits over just fine but the hub can't protrude past the center cap ring because of its depth. I see 2 options, machine the lip off the rim and look at other center cap options. Or machine a rebate out of the hub so it can pass thru the cap ring. Sketch below of what I am thinking.Attached File  20240425_161246.jpg   64.52K   5 downloadsAttached File  20240425_161254.jpg   67.7K   5 downloadsAttached File  20240425_165106.jpg   55.6K   3 downloadsAttached File  20240425_165342.jpg   36.46K   3 downloads
Sent from my SM-G988B using Tapatalk
#2 76lxhatch
  • 7,202 posts
Posted 26 April 2024 - 05:07 AM
Both the brake rotor and ideally the wheel should locate (directly or with the use of an additional locating ring) on the centre spigot of the hub. As long as it can still do that I don't see any issue with removing a little to clear the centre cap, there should be plenty of material at the small outer bearing end.
If there's a significant gap between the wheel and spigot, an alternative cap option may be one that fits from behind and doubles as the locating ring. The added bonus with this style is they are harder to steal.
#3 arrimar
arrimar
  • 3,134 posts
Posted 26 April 2024 - 06:18 AM
Screwed-on caps instead of push-in?
For example: https://lugnutking.c.../all/5-ear-caps
Edited by arrimar, 26 April 2024 - 06:21 AM.
#4 derrin71
derrin71
  • 491 posts
  • Name:Derrin
Posted 26 April 2024 - 07:45 AM
Sikaflex
#5 kimbo
kimbo
  • 110 posts
  • Name:Kim
Posted 26 April 2024 - 12:57 PM
Decided to get the hubs machined. All fits nicely now with no material difference to strength of the hub.Attached File  20240426_101039.jpg   61.86K   6 downloads
#6 RoyalPlum76SS
RoyalPlum76SS
  • 237 posts
  • Name:John
  • Car:SS Hatch
Posted 26 April 2024 - 02:04 PM
Just a side question Kimbo....what steering arms are you using? They look like they could be HQ-WB??
#7 dattoman
  • 16,487 posts
Posted 26 April 2024 - 09:11 PM
Decided to get the hubs machined. All fits nicely now with no material difference to strength of the hub.attachicon.gif 20240426_101039.jpg
This is what I would have done too
They look like 4140 CroMo... so certainly strong enough
#8 kimbo
kimbo
  • 110 posts
  • Name:Kim
Posted 27 April 2024 - 08:23 AM
Yep ...shorter power steering arms. I have fitted a BMW PS rack supplied by Peter Nash and this is how he does it.Attached File  20240420_132955.jpg   95.25K   11 downloads
#9 RoyalPlum76SS
RoyalPlum76SS
  • 237 posts
  • Name:John
  • Car:SS Hatch
Posted 27 April 2024 - 12:59 PM
Yep ...shorter power steering arms. I have fitted a BMW PS rack supplied by Peter Nash and this is how he does it.attachicon.gif 20240420_132955.jpg
Ahh cool, thanks mate that explains it. Peter certainly thinks outside the box with his Torana stuff.
Be interesting to see the bump steer curve for that set up.
#10 rexy
rexy
  • 3,715 posts
  • Name:Rexy
  • Car:Kia grand carnival!!!
Posted 27 April 2024 - 03:54 PM
Interesting.
I had the 17inch OS Hotwires and they had screw on caps.
Attached File  IMG_1245.jpeg   179.33K   3 downloads
#11 kimbo
kimbo
  • 110 posts
  • Name:Kim
Posted 27 April 2024 - 11:28 PM
Interesting.
Are they OS Formula's ?
#12 rexy
rexy
  • 3,715 posts
  • Name:Rexy
Posted 28 April 2024 - 01:03 AM
Sure are. These were from the first batch and I was given a choice of cap style and went with screw on.
#13 neglectedtorana
neglectedtorana
  • 1,028 posts
  • Name:Tom
  • Car:LX Torana Sunbird
Posted 28 April 2024 - 07:31 AM
That's a neat setup, all of it.
Who is Peter Nash? Business name?
Is the general idea to have the steering arms parallel to the road when the car is at ride height?
Where did the coil overs come from?
#14 kimbo
kimbo
  • 110 posts
  • Name:Kim
Posted 28 April 2024 - 01:30 PM
Pete works from home and is swamped with work so doesn't put himself out there. Some would call him the Torana guru and he has developed many solutions for problems that restorers come across. Reach out to him via https://www.facebook...mibextid=A7sQZp were he is an active member. Search him in the members list perhaps and DM him. Check out his posts for a sense of the work he does.
He is based in QLD.
I got the Viking coilovers from the Rod Shop.
Another example of the work Peter does is setting up Speed Hut gauges to replace the standard cluster.Attached File  20240221_184230.jpg   77.83K   4 downloads
#15 neglectedtorana
neglectedtorana
  • 1,028 posts
  • Name:Tom
Posted 28 April 2024 - 02:00 PM
Hi Kimbo,
Thanks for the answers, I will look up his stuff.
Cheers, Tom
#16 rexy
rexy
  • 3,715 posts
  • Name:Rexy
Posted 28 April 2024 - 11:54 PM
Looks like he has copied Heaths good work with the gauges.
#17 kimbo
kimbo
  • 110 posts
  • Name:Kim
Posted 29 April 2024 - 09:03 AM
I think it's the other way round. Heath puts a bit more into his to make them more original looking. However if you are not fussed about retaining the curved glass faces then Petes setup is cheaper.
