Engine won’t turn over by hand
Posted 29 April 2024 - 12:02 AM
Turned it over by hand no problem.
Now 6 months later I can’t turn it clockwise (from the front of the engine).
Surely it’s not seized just from sitting there in a garage?
Any ideas?
Posted 29 April 2024 - 08:23 AM
Not on your one, but years ago I bought a Centura that hadn’t run for about 2 years. We poured a bit of diesel in every spark plug hole, sprayed WD40 into the head, exhaust and inlet, left it 24 hours, turned over by hand no probs without plugs. Plugs back, fresh fuel and battery fired first go.
Posted 29 April 2024 - 10:49 AM
Bearings can get sticky after a while. Are you using your hands or a breaker bar off the harmonic balancer?
Posted 29 April 2024 - 02:47 PM
HI pull the spark plugs out, spray plenty of c r c in the plug holes it should then turn over, if you turned the engine over 6 months ago there should be no issues with the engine.
Posted 29 April 2024 - 07:19 PM
Plugs are out.
I’m about to start puling it down.
Posted 30 April 2024 - 12:03 AM
Will it move anticlockwise?
Posted 30 April 2024 - 06:50 AM
I'd undo the rocker posts and make sure it's not a seized lifter.
Posted 30 April 2024 - 08:20 AM
hi exactly what yel 327 has stated remove the rocker arms then see if it turns.
Posted 30 April 2024 - 09:00 AM
It could easily be lifter(s) and/or valve(s) so worth a try. A stuck lifter won't free up with rockers removed but not having the valve spring pressure on it might be enough to free it. If it is a lifter you are going to be up for talking the valley cover off it but possibly worth doing anyway as Holden V8's are renowned for their taste for camshafts, and it's far easier to change when the engine is on a stand.
Posted 30 April 2024 - 09:56 PM
Posted 30 April 2024 - 11:20 PM
Posted 02 May 2024 - 11:23 AM
Blown head gasket when sold to you.
Posted 02 May 2024 - 12:18 PM
Let me know if you need a hand as i am in Canberra too. I am pretty handy with the old 308's :-)
Posted 02 May 2024 - 10:35 PM
You didn't shove rags in intake & exhaust ports to seal it?
Might have to pull plugs soaks all the bores then every day or two try turn it a little bit or shove boroscope in there to see how bad it looks.
Posted 03 May 2024 - 10:44 AM
If it is as bad as it sounds, I reckon the heads will need to come off for a proper look. Any pitting in the bores means a rebuild.
Posted 03 May 2024 - 11:09 AM
Strip it and start again only proper way to do it
