Engine won’t turn over by hand
15 replies to this topic
#1 Johno
Johno
  • 209 posts
  • Name:John
  • Car:LX Torana
Posted 29 April 2024 - 12:02 AM
Bought a second hand 308 about 6 months ago.
Turned it over by hand no problem.
Now 6 months later I can’t turn it clockwise (from the front of the engine).
Surely it’s not seized just from sitting there in a garage?
Any ideas?
#2 4dabush
4dabush
  • 199 posts
  • Name:Adam
  • Car:73 LJ S
Posted 29 April 2024 - 08:23 AM
Not on your one, but years ago I bought a Centura that hadn’t run for about 2 years. We poured a bit of diesel in every spark plug hole, sprayed WD40 into the head, exhaust and inlet, left it 24 hours, turned over by hand no probs without plugs. Plugs back, fresh fuel and battery fired first go.
#3 Shiney005
  • 9,479 posts
  • Car:Toyota Mirai
Posted 29 April 2024 - 10:49 AM
Bearings can get sticky after a while. Are you using your hands or a breaker bar off the harmonic balancer?
#4 LCK186
LCK186
  • 361 posts
  • Car:71 CK
Posted 29 April 2024 - 02:47 PM
HI pull the spark plugs out, spray plenty of c r c in the plug holes it should then turn over, if you turned the engine over 6 months ago there should be no issues with the engine.
#5 Johno
Johno
  • 209 posts
  • Name:John
  • Car:LX Torana
Posted 29 April 2024 - 07:19 PM
I used a breaker bar. Won’t budge.
Plugs are out.
I’m about to start puling it down.
#6 rexy
rexy
  • 3,666 posts
  • Name:Rexy
  • Car:Kia grand carnival!!!
Posted 30 April 2024 - 12:03 AM
Will it move anticlockwise?
#7 yel327
  • 13,575 posts
Posted 30 April 2024 - 06:50 AM
I'd undo the rocker posts and make sure it's not a seized lifter.
#8 LCK186
LCK186
  • 361 posts
  • Car:71 CK
Posted 30 April 2024 - 08:20 AM
hi exactly what yel 327 has stated remove the rocker arms then see if it turns.
#9 yel327
  • 13,575 posts
Posted 30 April 2024 - 09:00 AM
It could easily be lifter(s) and/or valve(s) so worth a try. A stuck lifter won't free up with rockers removed but not having the valve spring pressure on it might be enough to free it. If it is a lifter you are going to be up for talking the valley cover off it but possibly worth doing anyway as Holden V8's are renowned for their taste for camshafts, and it's far easier to change when the engine is on a stand.
#10 Johno
Johno
  • 209 posts
  • Name:John
  • Car:LX Torana
Posted 30 April 2024 - 09:56 PM
I tried moving the crank bolt back and forth now it’s moving about 3mm each way then stopping with a clunk in each direction.
#11 Johno
Johno
  • 209 posts
  • Name:John
  • Car:LX Torana
Posted 30 April 2024 - 11:20 PM
Also just found a rusty plug, which points to a rusty cylinder
#12 Shiney005
  • 9,479 posts
  • Car:Toyota Mirai
Posted 02 May 2024 - 11:23 AM
Blown head gasket when sold to you.  :shoot:
#13 Redslur
Redslur
    Has been Torana owner
  • 3,536 posts
  • Name:Gerry
  • Car:HQ GTS Replica 350.
Posted 02 May 2024 - 12:18 PM
Let me know if you need a hand as i am in Canberra too. I am pretty handy with the old 308's :-)
#14 gtrboyy
gtrboyy
  • 3,207 posts
Posted 02 May 2024 - 10:35 PM
You didn't shove rags in intake & exhaust ports to seal it?
Might have to pull plugs soaks all the bores then every day or two try turn it a little bit or shove boroscope in there to see how bad it looks.
#15 Shiney005
  • 9,479 posts
  • Car:Toyota Mirai
Posted 03 May 2024 - 10:44 AM
If it is as bad as it sounds, I reckon the heads will need to come off for a proper look.  Any pitting in the bores means a rebuild.
#16 Ice
  • 15,178 posts
Posted 03 May 2024 - 11:09 AM
Strip it and start again only proper way to do it
