Front coils, part 2
4 replies to this topic
#1 Pete
Pete
  • 16 posts
  • Name:Pete
  • Car:1972 GTR XU1 x 2
Posted 24 May 2024 - 05:04 PM
Started to assemble the front end (May 72 build XU1) and we must be doing something wrong because it can't be this hard. Coil has to be compressed from 11" to 7" to go in, a feat in itself. Got the spring in, did all the parts up and the rubber bump stop is totally deformed. Then took ages to get the spring compressors off. Is there a trick to this?
Mate who is assisting  rebuilt an LC GTR and said that was no problem at all.
Any suggestions gratefully received.
#2 S pack
  • 15,717 posts
Posted 24 May 2024 - 05:36 PM
Don't use spring compressors designed for McPherson struts. Bump stop rubber is totally deformed. Which one? The one on the upper control arm or the lower?
#3 N/A-PWR
  • 9,636 posts
Posted 24 May 2024 - 08:03 PM
I use two car jacks to wind up the 5/8" coil springs into place,
 with the K frame out of car,
using the top shocky bolt to hold the frame:
Attached File  post-30158-0-90074300-1409479402 (1).jpg   36.87K   7 downloads
#4 Pete
Pete
  • 16 posts
  • Name:Pete
Posted 25 May 2024 - 05:33 PM
The upper one. The conical one.
#5 S pack
  • 15,717 posts
Posted 25 May 2024 - 07:41 PM
Yeah mine are squashed into a ball shape between the upper arm and the spring tower. I actually need to replace one that has split
