1974 GMH Service letters
Posted 29 May 2024 - 12:01 PM
Posted 30 May 2024 - 11:54 AM
Got any paperwork on the V8 Bedfords Chris?
Posted 30 May 2024 - 12:08 PM
Which engine Laurie? I have the parts catalogues, order procedures, release of GMH V8 letters and maybe more.
Posted 30 May 2024 - 01:10 PM
Laurie, give me a date range for V8 Bedfords and I'll see if there is anything in my collection.
Posted 30 May 2024 - 06:22 PM
By the way, they are not mine, just something I saw that I thought someone here on this forum might be interested in.
Posted 30 May 2024 - 09:20 PM
Posted 31 May 2024 - 12:39 PM
Laurie
Press release and on sale date for the Bedford with 4.2L and 5.0L was September 3 1979. This was the debut of the XT5 design V8 engine, a few months prior to it being available in VC then WB.
Posted 31 May 2024 - 02:07 PM
Yeah, I would just like to catalogue the differing parts on the 253 and 308 in the Beddys. Things like the thermostat housing, compressor pulleys and so on. A parts book would be great. A workshop manual would be even better.
Posted 31 May 2024 - 02:48 PM
No info but maybe in one of these manuals
Posted 31 May 2024 - 03:54 PM
They are essentially blue motors but have significant changes. Mains and big ends have different bearings, 5.0L pistons have heavier piston crowns and both 4.2 and 5.0L pistons have large dishes (to achieve 7.8:1). Camshaft is changed with a more gradual ramp. Valve stems are hard chromed and valve heads are carbon steel tipped. Double row timing chains. Starte motor, alternator and water pump are heavier duty. Engines have a larger flywheel to suit a 12" truck clutch. Sump is increased to 5L (from 4L), radiator is larger than on a passenger car. Fitted with the XT5 HEI ignition. Electronic governor set to 3800rpm. Carbys on both are essentially the same Rochester Dualjet carby as fitted to a HK/HT 307 just with the ADR27A spec emissions as fitted to US vehicles.
SAE net:
4.2L - 126hp@3800rpm, 208lb/ft@2400rpm.
5.0L - 145hp@3600rpm, 240lb/ft@2600rpm.
Posted 01 June 2024 - 12:41 PM
Doesn't look like it is listed there. TK is the model.
Was the water pump any different externally, or was it the retained bearings similar to L34?
Posted 01 June 2024 - 01:53 PM
It had a cast iron housing.
Dr Terry
Posted 01 June 2024 - 02:09 PM
Here are some photos out of the GMH archives.
Bedford V8.jpg 121.1K 4 downloads
Bedford V8 2.jpg 110.43K 3 downloads
Posted 01 June 2024 - 09:01 PM
Posted 02 June 2024 - 08:35 AM
I thought they were the larger bearing type like they had up until the end of the 5.0L in VS.
