Suzuki Sierra SJ70
31 replies to this topic
#26 SmacT
SmacT
  • 978 posts
  • Name:Sam
  • Car:LX 4dr 383, TKX, BW
Posted 13 June 2024 - 10:16 PM
My Torrie has a Holden 383 in her, I'll send you a vid. Ha ha
#27 yel327
  • 13,643 posts
Posted 14 June 2024 - 06:49 AM
I'm sure it'll sound good. Gunna be hard to beat a screaming 427 though!
#28 Shiney005
  • 9,603 posts
  • Car:Toyota Mirai
Posted 14 June 2024 - 09:52 AM
A low revving 2-stroke sounds a lot like a rotary - like rocks in a coffee tin.
You haven't heard a Commer Knocker.  They sound like hammers in a 44.
#29 yel327
  • 13,643 posts
Posted 14 June 2024 - 10:58 AM
I meant dirt bike 2 strokes! Detroit Diesel 2 strokes are loud too.
#30 clarky9999
clarky9999
  • 121 posts
Posted 15 June 2024 - 08:16 PM
Mine had a 4k corolla engine and corolla 5 speed, easy conversion and went not bad.
#31 SmacT
SmacT
  • 978 posts
  • Name:Sam
Posted 26 June 2024 - 10:24 AM
Being as I picked this up from a paddock, I stripped the inside to find any rust - it's pretty good considering, and I only found one bit I didn't know was there in the bottom of the Targa bar.
I stripped back the boot floor, which had lots of surface rust breaking through, rust converted and hit with KBS, same as I did for the Torana.
Attached File  IMG_4403.jpeg   522.66K   3 downloads
Attached File  IMG_4405.jpeg   574.05K   3 downloads
Had a prod around the D/S of the Targa bar, where a little plastic cover on the outside introduces water into it, and yep, rooted. I drilled the spot welds off incase I could just patch it, but the curved line means i need a shrinker stretcher to make, and I haven't got to that level yet! I am ringing around wreckers for one, they just unbolt, or can buy new panels from OS through Ebay. The Sierra was called the Samurai OS and also a Drover here, so lots of options.
Attached File  IMG_4429.jpeg   180.65K   2 downloads
Attached File  IMG_4431.jpeg   315.08K   2 downloads
Found lots of nods to this thing's farm life.
Attached File  IMG_4370.jpeg   177.48K   2 downloads
I still have huge spiders emerging from it from time to time, but otherwise it's in good nick. Just this other patch to make while I sort the Targa bar, and some minor rust on panels.
Attached File  IMG_4369.jpeg   103.85K   2 downloads
It's really easy to work on, takes up space inthe garage, and I don't feel the pressure I did with the Torrie. It's just fun! Probably should have started on a project like this in the first place.
#32 Shiney005
  • 9,603 posts
  • Car:Toyota Mirai
Posted 11 July 2024 - 08:55 AM
Not a lot of room to swing a .243 around in there!
