Disc brake conversion
disc stub axle steering arm Hoppers Stoppers
10 replies to this topic
#1 VerdoroLC
VerdoroLC
  • 12 posts
  • Name:Grant
  • Car:1969 LC Torana
Posted 18 June 2024 - 12:06 PM
Hi all
I'll shortly be doing a disc brake conversion on my 6 cyl LC using a Hoppers Stoppers kit - I know I need new stub axles but do I also need new steering arms?
I've seen some advertised on ebay as being suitable for disc brakes which made me wonder if they're different to the steering arms on a drum brake set-up.
Grant
#2 S pack
  • 15,726 posts
Posted 18 June 2024 - 01:46 PM
G/day Grant. Yes LC LJ 6cyl disc brakes use a different stub axle to drum brakes. That said Some of those aftermarket disc conversions use the drum brake stub axle and a conversion mounting bracket for the caliper.
#3 VerdoroLC
VerdoroLC
  • 12 posts
  • Name:Grant
Posted 18 June 2024 - 03:31 PM
Thanks Dave.  Unlike the CRS adaptor kit that retains the drum stub axle, the HS kit requires disc stub axles so I've already got those sorted.  Can I still use my existing steering arms from the drum set-up though or is a different 'disc specific' steering arm required?
#4 S pack
  • 15,726 posts
Posted 18 June 2024 - 03:48 PM
Steering arms are the same for disc and drum brakes.
#5 VerdoroLC
VerdoroLC
  • 12 posts
  • Name:Grant
Posted 18 June 2024 - 03:52 PM
Awesome, thanks for confirming Dave
#6 VerdoroLC
VerdoroLC
  • 12 posts
  • Name:Grant
Posted 18 June 2024 - 06:06 PM
While I've got you Dave, would you happen to know the standard offset for a 13" LC/LJ rim?  I plan to fit 15 x 6 rims to the front with a minus 12 offset and running 185/55R15 tyres (same OD as the current 175/70R13 tyres).  The Hoppers disc brake kit adds about 16mm to the offset which now has me worrying about clearance to the guards
#7 4dabush
4dabush
  • 226 posts
  • Name:Adam
  • Car:73 LJ S
Posted 18 June 2024 - 06:52 PM
Hi Grant,
I’m away at the moment but my rims were +25 offset on 7inch rims…I think… I know if I try 8’s I’ll need to go to the maximum offset I can get from Neale Wheels (where mine came from) which is +28. From the table below I think you’ll need to run more like a +25 or +38. Depending on the Hoppers kit, they push the wheels out a fair bit and from memory (others will say for certain, stock Torry rims were +19 or about 4.00inch backspace. Oh, and I went commodore stud pattern on my Hoppers kit thinking I’d have more wheel options, which I think was dumb…stick to big Holden/Ford, or standard Torry. Most wheels you’ll probably want can be had in blanks and drilled to suit with offsets to suit within reason.
https://www.wheelspe...com/wheel-specs
Adam
Edited by 4dabush, 18 June 2024 - 06:54 PM.
#8 VerdoroLC
VerdoroLC
  • 12 posts
  • Name:Grant
Posted 18 June 2024 - 07:19 PM
Hi Grant,
Adam
Thanks very much Adam, that's very helpful.  I'm dead-set on the Street Pro (007) Autodrags so will stick with the Torana stud pattern, but may now need to consider the 15 x 4 fronts rather than 6".
Cheers, G.
#9 S pack
  • 15,726 posts
Posted 18 June 2024 - 07:32 PM
I'll leave the wheel backspace/offset stuff in Adam's capable hands.
#10 yel327
  • 13,643 posts
Posted 18 June 2024 - 08:11 PM
Standard LJ 4.5" wheel is 1.33" offset. That is a positive offset of about 33.8mm. Gives a backspace of about 4.08" if my calcs are right.
GTR and XU1 5.5" wheel is 1.13". Positive offset of about 28.7mm. Should be a backspace of about 4.38".
The imperial figures will probably be rounded though, 1.13" is more than likely 1 1/8" aka 1.125". 1.33" will probably be 1 1/3".
#11 VerdoroLC
VerdoroLC
  • 12 posts
  • Name:Grant
Posted 19 June 2024 - 11:04 AM
Cheers Adam, appreciate the info.  I put those offset figures into  willtheyfit.com  and it seems as if I will need to scale back the rim size to 4", especially with the vehicle lowered.
Edited by VerdoroLC, 19 June 2024 - 11:09 AM.
Also tagged with one or more of these keywords: disc, stub axle, steering arm, Hoppers Stoppers
