Rare Spares V8 HEI distributor experiences/reliability
Ignition
5 replies to this topic
#1 SLRNovice
SLRNovice
  • 15 posts
Posted 09 August 2024 - 08:34 AM
Hi all, I am upgrading the ignition on my stock 253 to HEI and would like to hear your opinions and experiences on the rare spares electronic distributors. They seem to be a cost effective solution along with new coil but I am unable to find exactly what brand they are or any real world reliability information.
I haven't been able to source a VC-VH or WB Bosch dizzy and unfortunately the budget doesn't stretch to an MSD.
Is there any other options I should be looking at?
#2 SLRNovice
SLRNovice
  • 15 posts
Posted 09 August 2024 - 11:19 AM
Also, if i was to buy an old original HEI dizzy from commodore or WB what is the approximate cost to have one reconditioned if it's required?
Thanks SLRNovice
#3 claysummers
claysummers
  • 3,641 posts
  • Name:Clay
Posted 09 August 2024 - 12:47 PM
Depending on condition, up to $450 for a 6 cyl, as a guide. That is with Performance Ignition Systems in Melbourne. By the time you add the donor price it is the same or dearer than a new one, but at least you have a genuine Bosch module etc. apparently the non Bosch modules tend to fail after a year or two. Vacuum advance units can be an issue as well. You can still purchase the Bosch modules new I believe, but I haven’t priced them.
#4 gtrboyy
gtrboyy
  • 3,215 posts
Posted 09 August 2024 - 09:45 PM
I kept v8 hei dissy for an engine getting built....engine builder said you can buy new one & get them recurved for not much more than getting oem rebuilt/recurved
#5 yel327
  • 13,659 posts
Posted 10 August 2024 - 09:41 AM
I put a Goss HEI and coil on my HJ Premier, seems to work OK. Straight bolt in but you cannot put it in a HT-HJ V8 with the vacuum canister in the same location the points dizzy goes as the module box hits, you have to rotate it so the leads end up a bit messy. Original Bosch one will be the same though. Certainly a lot cheaper than finding a used one and rebuilding it, then buying a Ford rotor button, HQ cap and buying a coil to suit.
#6 SLRNovice
SLRNovice
  • 15 posts
Posted 11 August 2024 - 09:25 AM
Thanks for the great info more food for thought.
By the time you spend a few hundred $$ on second hand unit and then potential cost of reconditioning you are definitely up near the price of a new good quality unit. The old saying buy once cry once keeps talking to my sensible side haha
Also tagged with one or more of these keywords: Ignition
