battery
4 replies to this topic
#1 bat 53
bat 53
  • 518 posts
  • Name:albert
  • Car:lc gtr
Posted 22 August 2024 - 01:42 PM
g'day all
need battery for the gtr
what size style amps volts and so on
thanks albert
#2 N/A-PWR
  • 9,636 posts
Posted 22 August 2024 - 02:33 PM
A read:
https://www.gmh-tora...j-xu-1-battery/
#3 N/A-PWR
  • 9,636 posts
Posted 22 August 2024 - 03:22 PM
This Supercharge PSNS50P currently on special for $169 at AutoOne will fit: :3gears:
Has the negative at front, classic look.
 and height from battery tray to the bonnet rib is 210 mm where the negative terminal would be approximately:
NS50P
Classic, 480 CCA, SMF CAL
Size A46
Volts 12
Technology SMF CAL
CCA 480RC 75
AH 40
Length (mm) 237
Width (mm) 171
Height (mm) 182
Total Height (mm) 203
Approx Weight (kg) 13.6
Assembly D
Post Type STD
Ledge EL & FL
Accessibility TS
Hydro Eye Yes
Base Warranty (Private Use), Months 30
Commercial Use Warranty (Months) 12
Taxi/Rideshare Warranty, Months 12
Attached File  90626624.jpg   67.77K   2 downloads
https://www.autoone....HaL3p79D7m4X7Xi
p.s. I use supercharge in all my vehicles, and will not let you down. :spoton:
#4 jpxu1
jpxu1
  • 571 posts
Posted 22 August 2024 - 11:41 PM
A read:
This thread is about the smaller XU-1 battery. GTR's had the standard size battery fitted.
#5 bat 53
bat 53
  • 518 posts
  • Name:albert
  • Car:lc gtr
Posted 24 August 2024 - 09:42 AM
thanks JP
