Todays lesson.
20 replies to this topic
#1 Shiney005
  • 9,506 posts
  • Car:Toyota Mirai
Posted 05 September 2024 - 12:36 PM
The Holden V8 firing order (12784563) is exactly the same as a Ford's firing order. (15486372)
Discuss.
Attached File  holden-f5000-engine.jpg   70.94K   6 downloads
Attached File  PSEBP3023CTC.jpg   413.41K   6 downloads
#2 76lxhatch
  • 7,199 posts
Posted 05 September 2024 - 12:57 PM
I know Fords have a weird way of numbering their cylinders (possibly more than one variation depending on the engine), so guessing the V8 one in question would be:
1 2 3 4
 5 6 7 8
where a Holden is:
1 3 5 7
 2 4 6 8
making the cylinders the same. But they sound a lot different...?
#3 claysummers
claysummers
  • 3,579 posts
  • Name:Clay
Posted 05 September 2024 - 02:17 PM
I’m not feeling well teacher. Can I be excused please?
#4 Shiney005
  • 9,506 posts
  • Car:Toyota Mirai
Posted 05 September 2024 - 05:24 PM
1 2 3 4
 5 6 7 8
where a Holden is:
1 3 5 7
 2 4 6 8
Smack on!  I don't know why they sound so different though.  At high revs, the 308 is one of the best sounding motors ever.
Edited by Shiney005, 05 September 2024 - 05:25 PM.
#5 Dr Terry
Dr Terry
  • 3,323 posts
Posted 06 September 2024 - 08:18 AM
1 2 3 4
 5 6 7 8
where a Holden is:
1 3 5 7
 2 4 6 8
AFAIK Ford number all their V8s that way, but there are 2 different firing orders.
One of them is 1-5-4-2-6-3-7-8  & the other is 1-3-7-2-6-5-4-8
Dr Terry
#6 Bruiser
Bruiser
  • 840 posts
  • Name:Bruce
Posted 06 September 2024 - 09:32 AM
That second ford firing order is for the 351
289 and 302s are the same as a 308 then
Could explain why those 3 have a different sound at revs
than the 351
Thinking about the order of the pulses between the left and right
groups of exhausts the 308 and littler fords go
L-L-R-R L-R-R-L
351s would go
L-L-R-L R-R-L-R
Counting 1 to 8
Start the counting at 6, though
R-R-L-L-L-R-R-L
as opposed to
R-L-R-L-L-R-L-R for 351 which seems more even
I am thinking the timing of pulses through seperate twin exhaust pipes
could make a fair difference and how this could relate
to how much H or X pipes change the sound of a v8
Edited by Bruiser, 06 September 2024 - 09:35 AM.
#7 Shiney005
  • 9,506 posts
  • Car:Toyota Mirai
Posted 06 September 2024 - 10:33 AM
R-R-L-L-L-R-R-L. In my head, that is what the cammed 308 in my VK sounds like when idling.
#8 N/A-PWR
  • 9,636 posts
Posted 06 September 2024 - 10:56 AM
Not Ford, but interesting.
Laurie made me look at this firing order lesson:
https://www.youtube....h?v=30H7HKKhgXQ
Edited by N/A-PWR, 06 September 2024 - 10:56 AM.
#9 Bruiser
Bruiser
  • 840 posts
  • Name:Bruce
Posted 06 September 2024 - 11:57 AM
Sounds like me falling down a flight of stairs
#10 yel327
  • 13,591 posts
Posted 06 September 2024 - 12:13 PM
Heads make a difference too. My Overlander with its stock HZ red 308 and single 2.5” system with cast iron exhaust manifolds was quiet. When I put a stock VP 5.0L in it with cast iron manifolds and the same carby and exhaust it was way too loud, and sounded very different.
One of the reasons I think 253/308 sound bad is if you use early heads (pre HX) with dual exhaust and no crossover pipe they become thong slappers.
I still reckon one of the best sounding V8’s is a 427 BBC, 426 Hemi sound good too.
#11 LXCHEV
LXCHEV
  • 3,541 posts
  • Car:'76 LX - 383 Chev
Posted 06 September 2024 - 04:26 PM
According to this source - the Ford firing order of 1-5-4-8-6-3-7-2, which is the one we're saying is the same as the mighty Holden V8 - is only for the Ford Y block. 1950's stuff.
The Ford 289, 302, 429 and 460 engines - have a different firing order of 1-5-4-2-6-3-7-8.
Then there's the 351 having 1-3-7-2-6-5-4-8.
I wonder if siamesed exhaust ports (ie Holden 308 and SBC) would also influence the sound difference to that of the Ford?
Attached File  Common Firing Orders.jpg   158.88K   6 downloads
#12 dattoman
  • 16,485 posts
Posted 06 September 2024 - 08:12 PM
The best one is of course
1-5-6-3-4-2-7-8
#13 warrenm
warrenm
  • 2,117 posts
  • Car:1972 LJ Torana
Posted 06 September 2024 - 10:17 PM
There's only one firing order that matters, 153624, end of discussion. :spoton:  :stirpot:
#14 claysummers
claysummers
  • 3,579 posts
  • Name:Clay
Posted 06 September 2024 - 10:26 PM
Yep….
#15 yel327
  • 13,591 posts
Posted 06 September 2024 - 11:10 PM
Definitely. I reckon the HT to VL heads sound different to VN-VS.
#16 Shiney005
  • 9,506 posts
  • Car:Toyota Mirai
Posted 07 September 2024 - 10:15 AM
1-5-6-3-4-2-7-8
Cadillac 500 I'd wager.  There is another motor with this firing order.
  Chris Craft used to buy 283 blocks from GM to marinize (marinise?) for their boats. The Chev 283 firing order is 1 8 4 3 6 5 7 2, however Chris Craft re numbered the cylinders as they made almost every other part themselves including the crank and cam which made the firing order 1 5 6 3 4 2 7 8.........................for the starboard side motor. For the port side they had the motor counter rotating with a firing order of 1 8 7 2 4 3 6 5.
Attached File  283 firing order.jpg   139.15K   2 downloads
Attached File  136034316.jpg   55.97K   2 downloads
#17 Shiney005
  • 9,506 posts
  • Car:Toyota Mirai
Posted 07 September 2024 - 10:27 AM
I am still trying to get a handle on the Ford stuff. They sure like making life difficult.  The 302 is indeed 1 5 4 2 6 3 7 8, but the 302 H.O. is 1 3 7 2 6 5 4 8.
Then there is the 351 H.O. in 1990's Mustangs, Thunderbirds, and F100's which have the same 1 5 4 8 6 3 7 2 firing order as in the opening post, even though the emissions decal under the bonnet has the 1 3 7 2 6 5 4 8 order printed on it.  Mechanics must go insane over in the States!
Edited by Shiney005, 07 September 2024 - 10:29 AM.
#18 Shiney005
  • 9,506 posts
  • Car:Toyota Mirai
Posted 07 September 2024 - 10:52 AM
1-5-6-3-4-2-7-8
Also closest so far to the lead sequence in an L34. 1 5 7 3 4 2 6 8
#19 Dr Terry
Dr Terry
  • 3,323 posts
Posted 09 September 2024 - 03:10 PM
I was caught out on a job many years ago.
Back in the early 70s you couldn't easily find camshafts for 351 Windsor motors, which had a different firing order to the 289/302. But you could fit a cam from a 289/302 to the 351 Windsor by just swapping the ignition leads to match.
Anyway this XW GT came in missing badly. I checked everything including making sure that the firing order was correct. I wasted so much time on this thing checking & triple checking everything.
The firing order was cast into the inlet manifold, so I had to be correct, but no. I swapped the leads to a 289/302 order & hey presto it ran perfectly. After I finished the job I ground the numbers off the inlet manifold so the next guy didn't get caught out.
That was 45 years ago, yet I remembered that job as if was yesterday.
Dr Terry
#20 LJ RB30
LJ RB30
  • 1,027 posts
  • Name:Trevor
Posted 09 September 2024 - 04:38 PM
Holy crap Batman! Now that’s a curveball you wouldn’t expect 🤪
I found out years ago that V6 capri were numbered 1 2 3 down one side when I helped an old mate start his fresh rebuild in his Datto 1000 ute.
Had us scratching our head for a while!
My comment at the time was BLOODY FORDS!!
Dr Terry
#21 Rockoz
Rockoz
  • 4,016 posts
  • Name:Rob
Posted 10 September 2024 - 09:56 AM
If my memory serves me right, one of the racing car magazines did an article in the Bob Morris/Ron Hodgson hatches.
There were a few little pearlers of info in it, such as increasing the life of the cam and lifters, as well as them changing the firing order of the 308.
They claimed some improvement which I cant remember.
Rob
